Raising up a little stack |
Johnnyspeakerp
New Member Joined: 12 September 2020 Status: Offline Points: 6 |
Posted: 29 December 2020 at 8:49pm |
Hi all
I need to raise up my mini stack (2 X 10ā scoops + kick + Top) about 50 cm (20 inches) from the ground because I realized the height of the sections is crucial to make it sound properly. My first idea was obviously pallets but as the set will not be moved often Iām looking for a more definitive pedestal which will not sound or come in the way with vibrations. Ideas and experiences much apreciated!
infrasound
Old Croc Joined: 13 May 2011 Location: Brizzle Status: Offline Points: 2276 |
More scoops?
Otherwise, a wooden spacer between scoops / kicks (maybe with some nice carpentry), or breeze blocks underneath the whole lot has worked for me. You may need some thin rubber matting between the breeze blocks & wood to improve the interface.
jacethebase
In the past I have had wooden boxes made up for use as risers.
Make them strong, act like you are building a speaker! And fill with rock wool.
www.stage2sound.com |
jacethebase
jacethebase
Johnnyspeakerp
Thanks for the precious advices!
