  New Posts New Posts RSS Feed - Ramsa WP-1400
Ramsa WP-1400
bassdesigner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Topic: Ramsa WP-1400
    Posted: 16 September 2017 at 3:32pm
Anybody have any experience with these what are they like in bridge mode?
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 6:33pm
Manual says 800rms... and the only internal pic I found suggest the PSU is a little on the weedy side. I have a 400w amp with the same size PSU and I doubled up on caps for my own peace of mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 10:51pm
Been offered a few at a very good price and they kind of remind me of TOA power amps that are bomb proof!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 11:07pm
1 per bin might be ok... if they are cheap as chips have a punt
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2017 at 12:02pm
I have some Ramsa amps and I must say that they are some of the best built amps I have. Whatch the caps. They may need replacing. Otherwise built like a brick sh#t house. Panasonic is the parent company or was. I heard they don't make them anymore. Old ones Sanken fets newer NEC I think. ELNA caps. Should be fine if you sevice them. Not power monsters.
My WP 9150 's have 27 screws holding the top cover on. Bit OTT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2017 at 3:20pm
Have you ever tried them bridge into 4ohms I know it's not recommended but you never No?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Posted: 28 September 2017 at 3:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2017 at 12:19pm
No, mine are all 200w into 4r so bit pointless. I use them to run comps. They do sound ok. As I said I don't think that they are ment for 4r bridge. I think that they are really designed for installs. They will last eaons at low volume in a fitness gym or meeting hall. Wouldn't think that they will rinse the bass out fabric style for very long. Still a very well built amp though.
