RCF ESW1018 vs EV T18 (FR and Impedance curve) |
| Author | ||
Botabaixo
Joined: 25 January 2007 Location: Portugal Status: Offline Points: 18 |
Topic: RCF ESW1018 vs EV T18 (FR and Impedance curve)Posted: 30 August 2020 at 10:31pm |
Hi. This weekend I carried out a comparison between the T18 and the ESW1018.
Knowing that they are boxes with identical size, Here are the results:The frequency response was made with the box on the floor.Edited by Botabaixo - 30 August 2020 at 10:33pm |
Conanski
Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2757 |
Posted: 30 August 2020 at 11:26pm |
Unfortunately I think your comparison is useless, if you measured indoors in the space shown in the pic then you measured the room more than the speakers and that is why the response is nearly identical. Get these outdoors well away from structures and try again and I bet the results will be quite different.
For reference the factory response for the t18 is below.. ![]() Edited by Conanski - 30 August 2020 at 11:29pm |
Botabaixo
Posted: 31 August 2020 at 12:27am |
I don´t think that is useless, if I gona use it indoors.... I know the graphs from both boxes, they are very identical. The ESW1018 and T18 Frequency response: ![]() Overlay ![]() |
Jo bg
Posted: 31 August 2020 at 10:07am |
It will still be useless, unless you put it in a venue same size as the one you measured in AND put subs in same postion. even changing one meter postion will change response a lot, immagina a different shape and size room eith different absorption caracteristics. The only thing you can gather from this, is diffence between cabs, as you are measuring them close room influence should be similar. But the frequency repsonse has no absolute value, even different ceiling height will make a difference. |
Botabaixo
Posted: 31 August 2020 at 12:28pm |
1. The measurements were taken with the speakers in exactly the same position. 2. If the frequency of response is useless, how do you assess which speaker is best for a given circumstance? By ear?
mobiele eenheid
Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1563 |
Posted: 31 August 2020 at 1:51pm |
Useless is such a big word that seldomly fits every perspective, it's almost useless to use it. If your software has the ability set the gate before the first
reflection. Say the first (closest) wall is 5 meters away, the first
reflection (apart from the ground) will arrive in 30 milliseconds. In a
large space the ceiling is often the first reflection. If you set the
gate below this 30 milliseconds, it will be excluded from the
measurement. However a shorter gate time will limit how low you
can measure accurately. The lower you want to measure the longer the
gate time needs to be, so you might have to make a compromise between
reflections included and how low you want to accurately measure. |
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Posted: 31 August 2020 at 9:49pm |
ignoring the bump and the spike i guess both are tuned to about 50hz and are not useable much above 100hz.. - bet they are loud in their, narrow, passband, both dont look great imho tbh. :(
Conanski
Posted: 31 August 2020 at 11:08pm |
Wow they are pretty much identical, I didn't know that but it explains your results. Still, if you were to EQ the response to look sensible in that location you would likely try to fix at least a couple response anomalies(the dips at 58hz and 116hz) that the speakers aren't responsible for, so for that reason the measurements aren't of much value. P.S. The fact that those 2 dips are exactly multiples of one another strongly suggests a boundary reflection cancellation, and no amount of EQ would have any effect on them.
Edited by Conanski - 31 August 2020 at 11:16pm |
bob4
Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1924 |
Posted: 01 September 2020 at 7:01am |
Useless is a strong, but appropriate word in this case. The only thing you can see from the graph is the cancellation from the back wall, which is abit over 3 m away, and results in cancellation at about 57 and 114 Hz.
It is common and agreed practice that subwoofers need to be measured outdoors. Whining and denial doesn't change the fact. Listen to the advice, there are very experienced and smart people on this forum (i don't count myself in that group). They answer for the fun of it to educate newcomers. Listen & Learn Edit: while the measurement result is pretty much useless, i don't think your effort was useless. You practiced using the software, you got some data, now it is just a matter of learning from it. If your data is useless, you have to simply get new data.
Edited by bob4 - 01 September 2020 at 7:06am |
sushi
Joined: 27 March 2012 Location: Milan Status: Offline Points: 95 |
Posted: 04 August 2021 at 7:05pm |
Good effort in test and research always pays. You always learn something, maybe it's not that information you were looking for but it's still a good thing.
The most important and decisive thing determining a speaker system's response is the environment around the system itself. Have you ever tested a loudspeaker indoor and felt sound pressure, but later found the volume wasn't enough outdoor? Well, it's all about sound reflection. Shortest reflections can alterate real sound perception: waves from the speaker that bounce on the cieling or on nearby walls and get to your hear a few milliseconds after the main soundwave coming from the box. They change the actual speaker response, ehanance or cancel some frequencies. If we can hear it, microphones will do as well. So, if you put those two boxes in half space (a field, or an empty parking lot where the floor is the only significant boundary) you surely going to get some changes in your graph, and that would be the common way to get sub speakers tested. Anyway, the cabs have the same driver but different loading, i bet some differences have been totally flatten by the overall room's response which is the one you measured this time. It would be interesting to see outdoor measurement graphs. As an ESW owner, i'm going to get my 4 measured soon. I loaded them with the 801. Cheers! Edited by sushi - 04 August 2021 at 7:14pm |
kedwardsleisure
Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 5157 |
Posted: 04 August 2021 at 10:30pm |
In this neck of the woods the ESW1018 is known as a one-note bass box. |
North Staffordshire |
