RCF Event 6000 and ESW 1018 crossoverpoint |
serioussound
Registered User Joined: 01 December 2013 Status: Offline Points: 443 |
Thanks(1)
Posted: 11 November 2018 at 6:33pm |
Have recently come over setup with:
2 cabs RCF Event 6000 2x15+8”+1” 2 cabs RCF ESW 1018 1x18” For now I use the Event 6000 passive. For what I know many use this speakers together but how to cross between the 18” and the 15”? Some kind of overlap in the bass range for maximum performance? It feels like a shame to cross away everything under 120 Hz For the 15”:s? All ideas welcome here..
nickyburnell
Not an ideal situation. Maybe a gentle slope and 90hz?
serioussound
Yes maybe but for what I know they pretty ofte are used together in systems but I cannot find any info about how to cross them properly...
serioussound
I dont know what is usually crossing between dual 15” tops to 18” subs?
nickyburnell
Well if it is all set up properly then use the 2x15 bit as kick, after all the 8 does most of the mids. Just mess with 80 to 100 hz and slopes until you like it. Personally I would prefer 2 x 18 cabs to one of those 6000's (damn good cab) then 80/90 hz with gentle slope to create a bit of overlap. My JBL 2226 cross to Event 1000 at 100hz, not that that helps
serioussound
Sorry my english is bad which cab you mean is good and why you think its so damn good? :)
What do you mean by ”not that that helps”?
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2544 |
serioussound
Ok lucky I have 2 more 1018 laying around just need to refurbish them a bit
