RCF LF18X400 |
Post Reply | Page 12> |
DJ Tosco
Registered User Joined: 09 June 2005 Location: Italy Status: Offline Points: 20 |
Posted: 26 June 2005 at 4:49am |
I looked at the datasheet and this woofer appears to be a monster. What about using it in a 186 (or 1850 horn)? I think it will fit very well the 186 |
djbolo
Registered User Joined: 30 June 2005 Location: Poland Status: Offline Points: 6 |
Probably it can play even from 40Hz with -3dB. It's great speaker for 186 or 1850.
Timber_MG
Registered User Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Uhm, I somehow have my doubts about 40Hz -3dB as in real life such
horns have rising response anyways and 50Hz is probably a good target
for the horn in a stack of 2-4.
DJ Tosco
I have some questions. I don't know how to modelize 186 and 1850 horns in hornresp, in particular to calculate the path lenght and the throat chamber. Rog said that 186 horn offers a hi-fi bass, so I expected a more extended LF response, but from the plots I saw that 1850 horn has a lower f3. That's right?
DJ Tosco
I plan to build 4 horns powered by two QSC RMX1850HD bridged What is the best about spl and bass extension? 186 Horn with RCF LF18X400 186 Horn with RCF L18P300 1850 Horn with RCF LF18X400 |
rastaman
Registered User Joined: 20 May 2005 Location: United States Status: Offline Points: 421 |
If you read further you'll see he talks about the fact the 1850 has a
snappier transient. It's not so much to do with extended LF response as
the fact that it doesn't respond as fast as the 1850 so sounds
'smoother'. Kind of like dripping syrup in your earhole.
There's a provided spec for drivers for the 1850horn, EBP over 125. The FAQ covers how to calculate EBP.
The 18LX400 only has an EBP of 96. Also don't forget there's no such thing as a cabinet plot, it's a plot of a specific driver in a specific cab. If you change the driver out, the response of the cab will change too. Don't you just hate math The L18P300 is mentioned as suitable for the 186, so use it for a baseline and compare the 18LX400 to it. Good luck with the hornresp idea. Edited by rastaman |
DJ Tosco
Thank you for the post. I know that these drivers work properly only mounted in a 186 Horn, but I didn't manage to modelize these horns in hornresp. The calculated response isn't very similar to Rog's graph. Now the question is how to set hornresp for a good simulation and choose the right driver from RCF catalog. I think that LF18X400 is awesome in Xmax, Xmech (almost indestructable) and the fs is low. However, L18P300 is the recommended driver for 186 horn |
rastaman
fs is not really important in a horn driver as I recall. You want a
good strong BL (motor strength) and a fairly rigid structure, a
nice low Qes.
Rog says in the FAQ EBP > 125 and Qts < .28 for a good horn driver, the Qes on the LX400 is .27 just within it, but you could maybe do better. That said the L18P300 has a lower BL and a higher Qts. Weird. Looking through the RCF range (I assume because it's in Italy?) I see that all the driver specs for 18's are similar, the one that stands out is the L18S800, it has a slightly higher fs which is generally better for a horn. Although it's Qts is .29 which is one over Rog's magic .28 it has an EBP of 130 which would suggest it could get quite loud in an 1850 horn. It's BL is also slightly better than the LX400. As it's Qts is still lower than the P300, I think it could be a contender, though it's no PD1850. However if you can afford it (I assume neodyium drivers are more expensive) the best looking one is the LF18N402. Nice low Qts of .24, an EBP of 150, and a BL of 29. Efficiency is a little down on the L18S800 but I think it would handle more power which should make up for it. This is going to be one of those things, once you can get it modelled right you'll have lots of fun modelling all the different drivers. Ask about however, don't take my word for it, I wouldn't Edited by rastaman |
DJ Tosco
The neo drivers are too expensive for my budget. The Xmax of the 18S800 is quite small, so I can't reach an awesome bass output. So, I'm thinkin' about P300 or X400 in a 186 horn. What do you suggest? And again, is the SPL difference from 186 and 1850 so high? |
Sencesync
Registered User Joined: 17 April 2005 Location: United States Status: Offline Points: 180 |
sence iv been reading along, my guess is, the graph for this "1850horn" is probly modeled for multiple horns.
*if anyone hasnt had a go at it, the post about a punisher horn in "general" tells why i dont know a hole lot about horns yet...* but to my knowledge as for now, a singel horn wont get you deep pounding bass if im correct? and so there for you would need multiple horns or a "stack". and also that i know of after 2 hours of reading. yes a good 125 and up EBP , 22.5BL and up, low QTS. to what i see so far toying with hornresp. i do see a higher Fs helps a bit, but not much. my sugjestion would be a P300. cost effecient and after having a look at this 186horn seems that it would do fine. i think i would use a eighteen sound 18W1000 for the 186horn though, cost less (one) and two has a higher EBP and BL and handels a good 1000watt rms |
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Some types of a single horn will get you deep pounding bass, take the lab horn sub for example. Also the servodrive basstech 7 or Funktion One Infrabass 218 which gets down to 20hz on its own. Yes,RCF L18P300 would work well in the 186 horn, but 1850 horn needs driver will even higher BL.
Sencesync
hey wow, those are nice haha.
