RCF LF18X400 |
Post Reply | Page <12 |
djtosco
Registered User Joined: 26 September 2004 Status: Offline Points: 58 |
Finally, for a 186 horn is better a P300 than a X400? But the X400 appears to be similar to PD186 and has a longer xmax.. thank you for the reply! |
DJ Tosco
Registered User Joined: 09 June 2005 Location: Italy Status: Offline Points: 20 |
What about the amplifier? I'm planning to buy 2 Crown MacroTech 2400 and running them 4 ohms bridged...
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
wel yeah the labhorn does kinda work on its own because of its large mouth area,but the response will still be sloped. I wouldnt fret over tiny differences in Qes etc - its not like every driver of that model will be within 2 decimal places of each other... Be aware that the horn loading will raise the impedence seen by the amp by up to half(case for 4ohm drivers sometimes). Probably less if its a small stack.
