  New Posts New Posts RSS Feed - RCF LF18x451
RCF LF18x451
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 5:22pm
Originally posted by Taariffj Taariffj wrote:
Are you saying with the 451/ k20 on 4 the pd 1850/2
Will have better performance/ spl/ louder?
Have never used, heard PD1850/2.
I know the V18-1000/B&C 18TBX1000 work excellently in standard  Scooper, and K20 could easily drive 3x per side, if on decent mains power source.
What makes of 18" drivers, do you have easy access to?
Taariffj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taariffj Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 5:31pm
I’m in Toronto, Canada., I can get basically anything I need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 5:36pm
Can you get Oberton drivers?
Oberton 18XB1500 may well appreciate the tightness of your Super Scoopers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taariffj Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 6:06pm
http://www.bluearan.co.uk/index.php?id=OBN18XB1500 - http://www.bluearan.co.uk/index.php?id=OBN18XB1500
I will look into this driver, as I’m not familiar with the brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 8:54pm
Why would that rcf not work?
If you listen to Lev, the 18NLW9601 is the crappies 18 inch for a scoop. Which took him about 4-5 years to finally realize that it actually spanks almost everything out there in a right scoop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taariffj Quote  Post ReplyReply Direct Link To This Post Posted: 08 February 2019 at 9:47pm
The woofer works ok, I was asking if anyone using it in scoops or which design
Would be best suited for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 7:51am
Originally posted by love2all love2all wrote:
I had these in scoops - went back to PD very quickly. Very power hungry and not optimum situation using heavyweight amps on 13amp supply - just doesnt get the best out of them...
@Marjan, maybe you should have read the above first !?
And here endeth my input on this thread..
Father-Francis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Father-Francis Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 10:04am
Not all of us play from 13amp soc’s so sometimes the info or advice shouldn’t be important.
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 10:36am
I don't really understand the whole 13A thing. A 13A plug with 13A fuse on a sensibly loaded 32A ring would in all likelyhood give you more power on tap than a 16A ceeform
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 12:02pm
Might as well smash your head against a wall mate. Never mind that if you aren’t melting the plug, popping a fuse or tripping a breaker you have 26A to play with for peaks. Not that said K20 will rarely draw over that unless you’re loading the shit out of both channels and playing some waves at the impedance minima.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taariffj Quote  Post ReplyReply Direct Link To This Post Posted: 09 February 2019 at 3:35pm
Anyone ever did any simulation with the 451 in scoops
Or can do it?
haystacK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote haystacK Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2019 at 6:08pm
I've been running the LF18x401 in Wardrobes and quite like it though I haven't yet measure output.
Levyte, any chance you can share any opinions on the specs for the 401 based on your experience?
