  New Posts New Posts RSS Feed - RCF replacement 12" SRM450.
markie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Topic: RCF replacement 12" SRM450.
    Posted: 28 July 2022 at 1:54pm
I have a mate coming round tomorrow as his speaker got knocked over on his last gig. The first thing that comes to mind is obviously a shifted magnet as he said it landed with a hell of a thump.
Apparently it's the RCF version of the Mackie SRM-450 (passive).
Can anyone tell me the model number of the appropriate replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 2:55pm
I didnt know RCF did a version of the SRM450
The SRM450 was active, not passive, and came with either a cast aluminium driver of RCF manufacture (as RCF were owned by Mackie at the time) or later on by a pressed steel driver.
The RCF cast driver was the same one AFAIK as fitted to the RCF ART300 series which were also marketed as 'Mackie Industrial' however they did not share any other features.
But maybe we're a bit premature just yet
Edited by kedwardsleisure - 28 July 2022 at 2:55pm
North Staffordshire
cuivenion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cuivenion Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 4:15pm
This one is listed as srm450 mark 1 and art 300.
help!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 4:38pm
My buddy is not exactly a speaker nut, I was only going by what he said. I did know the RCF/Mackie history and that some of their cabinets were the same with both brands. For example the Monitor 8 was marketed as both Mackie and RCF.
My intention was simply to find out what I could in advance of his visit. Looks like the LF12G301 may be the one.
Thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 5:19pm
Plese note that passive and powered Art300 boxes were not using the same 12 inch driver.
Might be same case with the Mackie too.
partya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote partya Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 11:45pm
The passive version of a Mackie SRM450 is a C300z.
Then there are different versions of the first series, the second and third series were continual with their drivers.
The Eminence Delta Pro 12-450a is a direct replacement for the first series and the Celestion TF-1230s is a replacement for the V2 / V3s
I've probably just complicated things........
Turn it up! Turn what up?
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 28 July 2022 at 11:58pm
I have used the Eminence Delta12LF in the Behringer version of this box(B512DSP) with good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote markie Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2022 at 2:04pm
Well. how simple was that!!!!
No stuck magnet, no blown coil.
The LF+ lead had come off the crossover.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2022 at 5:18pm
 Great stuff, love a simple fix! Smile
Andylaser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andylaser Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2022 at 6:55pm
Good result. Smile
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
