re drilling 1850 baffle, help.. |
Page 12> |
AJ ![]() Registered User ![]() ![]() Joined: 08 May 2009 Status: Offline Points: 156 |
![]() ![]() ![]() ![]() ![]() Posted: 24 July 2009 at 6:33am |
Hi
Does any1 have any pointers to make re drilling a baffle on 1850 cab from pd1850 to v18 as stress free as possible and any advise on the best filler to use?? thanks in advance adam |
stitchy ![]() Young Croc ![]() ![]() Joined: 07 October 2007 Location: Nottinghamshire Status: Offline Points: 996 |
hi mate i would use car body filler sets nice and hard P38 from halfords £6-7 others may use other fillers see what they also recommend
cheers stitchy
Father-Francis ![]() Old Croc ![]() ![]() Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2729 |
Adam open the cab from the top, sand down remove screws , carefully .
thats what i´d do |
luke_0301 ![]() Young Croc ![]() ![]() Joined: 31 May 2009 Location: lincolnshire Status: Offline Points: 644 |
only do this if it is marine ply! a friend tried this with his cabs made from 18mm wbp,and you will end up splitting the top as it comes off! if it was glued well enough that is!
more bass please
nickyburnell ![]() Old Croc ![]() Joined: 06 February 2005 Status: Offline Points: 4410 |
biotec ![]() Old Croc ![]() Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2931 |
drilling the holes at the back of the chamber will be extremly difficult as you probably don't have a enough room to get a drill chuck in. Perhaps you could use one of those flexible drill shafts? I have never used one but they look useful if they work properly.
Francis's suggestion is best if you can do it without mullering the cab. Taking a crowbar to your pride and joy is always painfull. If the top doesn't come off without a fight when you have removed all the screws (including the brace), I would carefully cut along the joint using a plunge saw. Make sure that the saw blade thickness is in the end panel so that you can just replace the whole panel once it is off.
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11682 |
Consider using clamps rather than bolting through the chassis perhaps. Means you don't have to be quite so accurate with the hole positions.
Dom ![]() Old Croc ![]() Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Or just use 1850 drivers... A lot less hassle...
shagnasty ![]() Old Croc ![]() Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7685 |
Whip the screws out the top and use a festool saw on a guide to slice the top off the cab, you loose 3.2mm of material which if you are good can be 0.2mm of cab and 3mm of lid, screw lid back on upside down and make good with P38....
levyte357 ![]() The 10,000 Points Club ![]() Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Yes... I have 2x of them for sale... ![]() |
Thanks for all of your suggestions, I don't really feel confident enough to start hacking the cabs apart my self. The clamp idea sounds like the best bet, does anyone know where i can get suitable ones from at all?
any1 please? bluearan seem to stock them but would this be ok to hold an 18inch driver in place?
Page 12> |
