rebating??? |
Post Reply | Page 12> |
tom thumb
Registered User Joined: 19 December 2017 Location: hungerford Status: Offline Points: 24 |
Posted: 15 January 2018 at 11:11am |
Hi all, Ive just finished build a hog using butt joints but im not too happy with it so i have decided to router the sides to be more precise. Would a depth of 5mm be sufficient or is it 9mm to be half the thickness?
thanks
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2126 |
5mm is fine
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
snowflake
half the thickness is excessive. most routers I have used have had 3mm steps on the depth gauge so either 3mm or 6mm (though you would probably have to do two passes rather than 6mm in one go).
cravings
i've always done 5mm, it feels about right and it makes for easy sums, adding 10mm to all the relevent panels.
tom thumb
Thanks all :)
urban mischief
tom thumb
one more thing! rebating or biscuit joints?
urban mischief
charlysays
Registered User Joined: 16 June 2015 Location: Wales Status: Offline Points: 413 |
I guess it depends on the design but I've never had a problem with just butt joints and loads of screws and generous use of titebond 3. They are cubo subs though which are very well braced for their size.
I have a pair of the same cabs which are rebated and if anything the butt jointed cabs sound more solid due to the copious amounts of glue and screws I used. with MDF there's probably more advantage in rebating and the material is quite weak compared to 13lam birch ply.
solution
Young Croc Joined: 26 June 2005 Status: Offline Points: 767 |
Just found this topic while researching rebate joints. Total newbie at building cabs so have been reading through loads of stuff online. What's the best bit for 18mm x 5mm rebate cuts in 18mm ply. Something like:
46/44X1/4TC 24mm Rebater - 1/4" ShankWould you then use a jig guide along with the bearing to make sure you don't cut more than 18mm? Edited by solution - 07 February 2018 at 9:48pm |
Bassmentality: Ska, reggae, funk & Hip hop every month @ The Cellar, Oxford
odc04r
Well that bit would work for edges of a sheet but if you are doing more than a few cuts (especially repeat cabinets) most people make a jig and then use a a collar fitted to the router to control the motion through the jig. There is no bearing on the cutting bit, it is just a straight cutter of appropriate diameter. This then takes care of all the external and internal rebates on a sheet with one pass. Typically you'd rebate both side panels and then slot the rest in + fix.
If you only have a few cuts to make I'd probably use a collar with a straight edge guide, or a straight edge clamped to the board that I could then run my router base down. Still a non-bearing straight cutting bit though. |
Dub Specialist Sound
If you go the Jig route, just make sure you take into account your off-set of router bit and the Bush Guide of your Router
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Can anyone point me toward good guide for rebating out joint for speakers?
solution
thanks for the responses. I'm total router novice, can anyone point me towards a jig tutorial?
