Recomend me a replacement sub |
Mrd999
Young Croc Joined: 09 May 2012 Location: Cambridgeshire Status: Offline Points: 515 |
Posted: 20 June 2016 at 4:42pm |
Have been getting a rather nasty burning smell in my van recently,like the smell a clutch makes when it's burning up .
I have also had 25 amp fuses pop,replace fuse,amp and sub work fine,turn it off,then back on again and fuse has popped. Was getting some tyres fitted the other day and decided to have a bit of a better look,turned out there was smoke coming from the port on the sub,it's in the back of the van,sealed in behind the metal firewall. I have a Fusion encounter fe402,running bridged,into a Fusion encounter sub,ex wife bought it for me,as a package deal,with a jvc headunit. Took out the driver and it was rubbing like feck.. Took the cone out of the basket and this is what I found,guess that was the cause of the popping fuses... Can anyone recommend a decent replacement driver ? Here are the specs.
Cheers |
What goes around, comes around
APW
Young Croc Joined: 13 November 2012 Location: Kent, UK Status: Offline Points: 1173 |
"Recomend me a replacement sub"http://subway.co.uk/menu/subs/classic/meatball-marinara-classic.aspx Seriously... Have you checked the amp hasn't gone DC, the state of the VC and the popping of fuses would suggest it has?
Edited by APW - 20 June 2016 at 5:29pm |
Mrd999
I haven't tried it,but you may be right,not sure I want to try any of my decent drivers on it and risk messing up a pd of xb
Mrd999
What would be the best method of checking ? Putting a meter on the outputs ?
APW
Yes,
with no signal put the meter on DC volts and measure across the speaker outs on the amp... any DC voltage greater than about +/-100mV is not good, 500mV is bad..
Edited by APW - 20 June 2016 at 7:23pm |
