  New Posts New Posts RSS Feed - Recommended sub cabinet for Hk 15’ 400w driver
Anora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anora Quote  Post ReplyReply Direct Link To This Post Topic: Recommended sub cabinet for Hk 15’ 400w driver
    Posted: 09 August 2020 at 10:51am
Hie Guys, i have an extra 15inch 400w driver  Hk driver that has been lying around for a while now and would like to make a cabinet for. Gathering driver specs for Hk audio was a bit of a challenge even on their website but i managed to get a few which i have included down below. Your opinions will be most welcome guys on this relatively cheap driver of mine LOL
Frequency response -10 db:42 Hz - 130 Hz
Frequency response +/- 3db: 50 Hz - 130 Hz
Sensitivity 1W/1m (Half space) 104 db
Maximum SPL @1m, 10% THD: 126 db
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2020 at 2:33pm
That's not the specs of the driver, that's the specs of the driver in a cab.
There will be a model number on the driver somewhere, maybe on the back of the magnet or on a sticker on the side of the magnet. Post that model number up and you'll get an answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anora Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2020 at 3:19pm
Ok there are many numbers but i will type them now though i dnt know what they mean kkk. 994079     1512668/B its not clear.    8 ohm      67-0129A0417 61
