  New Posts New Posts RSS Feed - Reduce MT-130 horn
Reduce MT-130 horn
vicenturi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vicenturi Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2014 at 10:32am
A model coming soon. I'll upload some measurements when finished.
Mattias Andersson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattias Andersson Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2015 at 9:35am
Hey! Your light version of the mt130 is an interesting project.
Did you do any measurements?
I am thinking of building some mt130 too, but the full length version, dual 12's and a 2" hf driver.
PavelP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PavelP Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2015 at 11:52am
I think there's no need to shorten mt-130 -- it's short enough.I'll tell you more, it's not long enough to work with es18.
First of all replace 2xPi with 4xPi because top is sitting on subs, so it is a free space. Real response will be about 300-350Hz 0db or 250Hz -3db. Second, if you're planning to listen to music, sub shouldn't be used up to 200Hz. 150-180Hz is the limit for such a construction.
Try mt121 without limmer 042, because it's a horn for semi professional very compromised use with small subs. You need at least 1xmt121 with 1xes18 to reach a normal pressure level and match each other.
