reduce the back volume of a mid horn |
Post Reply | Page <123> |
Angelow
Registered User Joined: 17 March 2010 Location: italy Status: Offline Points: 199 |
damn, I see this change very difficult :(
gen0me
Bad part is that you cant measure the original driver :(
Btw. Some wizards recone leaving old membrane. Maybe this would be a way to go.
Angelow
I have two of these boxes, one with a burnt driver, and one still working. let's talk about stuff produced in 1985!
The recone kit can only be found for new versions. At the practical test the neodymium rcf cone is less efficient than the original, but has a power handling more than 3 times higher (700w instead of 200w)
In the 1980’s, “Bigger Is Better” was the concept. Large horns with high efficient speakers were common. Today, smaller and easier to transport is the concept. Efficiency is traded off for more power handling in which, you can make up the loss in efficiency by high wattage amplifiers to, achieve greater SPL. Those are very good horns you have there. You should get far better coverage horizontally with those boxes than the majority who build their own horn-loaded mid cabs. Best Regards, |
Angelow
with the neodymium rcf woofer according to you how much can I cut down?
I would have thought a cut at the top 800 / 1000hz with a driver 2 " How many liters can the box be big? thanks :)
Personally, I would not cut it. All you are going to do is destroy the box's performance. What little chamber that is left to extend the low frequency response of the 12 inch driver is needed. Best Regards, |
Angelow
but below I have the tham 15 mk2! sounds good at 150hz or better still at 120hz, 180hz already loses a bit, a horn like that can make 150hz?
I would not want the 12 to be destroyed by over-excursion! if I calculate with a winisd a volume per room closed as a midrange is that volume behind the horn? thankxxss!
You would have to scale the internal chamber of the horn in WinISD to determine what the 12 inch is seeing in terms of frequency response. It may be best to just create a new smaller box for the horn instead since you pulled the horn out of the old box. This will allow you to compare the old design to the new design (Hear the difference) which, will tell you how much low frequency loss will come into play by using a smaller box. The above would be the safe method instead of butchering an old box based on opinions of others who have no on hands experience owning such a design. When it comes to such modifications you are really on your own to determine if downsizing a cabinet will meet up to your requirements from a sound quality standpoint. Best Regards, |
gen0me
What for scaling down the rear chamber?
Make it smaller as you want. Chamber standing wave should be higher than bandwitch. In current size it will be in the bandwidth but not always you can notice the effect of the rear chamber on char. If you make it smaller standing wave can only go higher. I think your flare should go higher on axis. Cant say much about dispersion without sims though. So your cross should be very safe.
Edited by gen0me - 29 August 2018 at 3:08pm |
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
yeah just make the rear chamber as small as you can...
fatfreddiescat
WINISD won't model the low end cutoff of a horn as your dealing with reactance annulling, hornresponse and akabak will, hornresponse being much more user friendly for this purpose. A smaller rear chamber may well increase the low frequency output with a sharper knee at cutoff. If you can just bags with wet clay, sand or whatever you can to fill the air space in the chamber and listen to the change, preferably measure with a mic, pretty much any mic will do as just checking for relative changes, may even find an app for your phone will do the job for a basic check of effects the changes are having.
Possibly, you are mistaking internal chamber of the horn to canal of the horn. I am talking about the internal chamber of the horn. Under those circumstances the method I suggested does work in WinISd for I did it nearly 20 years ago with some large 180 Hertz Straight Horns. Straight horns with vents are a hybrid in which, follows the same principal as a reflex cabinet in terms of the rear chamber and port interaction.
Best Regards, Edited by Elliot Thompson - 05 September 2018 at 1:29pm |
