Reducing off site bass |
Post Reply | Page 12> |
citizensc
Posted: 17 September 2021 at 7:09am |
Hi Guys
Over the weekend just passed I coordinated the first edition of a small dance music festival ~1000 attendance Over all, I think it went well, feedback was very positive and people are already asking about the next one! One big issue we had was off site bass. The festival is about 4km from a town, for the most part people in the town reported they could hear nothing but we did get two noise complaints. This may sound insignificant but as a result we had to dramatically turn the volume down in the second night. We have already begun the planning stage for the next one in April and I am looking for effective strategies for reducing the off site bass. A little more info: -The stage is pointed the opposite direction of the town -The system is in a stretch tent with a closed back -The system consists of 12 punishers and 4 xtros in two ground stacks -There are no issues with mids/highs at all, the issue is bass (<120hz) -The stage and sound system are contained by a 10x15m stretch tent Some ideas of how to reduce bass behind the stage (in the direction of the town) -build horn extensions, something similar to the x-horn from void - in theory a greater radiating area results in better directivity -Hire some kind of noise barrier - https://echobarrier.com/product/h8-acoustic-barrier - Cost? Effectiveness? Will the bass just go around it? There are a lot of euro/UK members on here and I can imagine you guys content with these issues a lot, especially with outdoor events and high population density relative to Australia? What kind of measures have you guys uses? how effective was it? |
https://www.facebook.com/voyager.system
@voyager_soundsystem |
APW
Thanks(1)
Cardioid/end fire sub array. Edited by APW - 17 September 2021 at 10:08am |
AndyWave
Registered User Joined: 30 March 2008 Location: Finland Status: Offline Points: 380 |
Hire acoustic tech with noise monitoring stations to the direction of complaints. That would solve also false noise complaints from people who don't appreciate your kind of music... And the dedicated noise measuring tech will have eye on the measurement stuff during event and avoid tampering. A competent tech would also help You to tune and position your bass rig with maximum cancellation to the relevant direction. I assume You have some kind of legislation of decibel levels which are considered as nuisance. -3dB from that and You win with evidence, if You let me say. And Yes, cardioid array, or one step further, end fired array iow 3 or 4 subs in a row with appropriate delays. At some point this costs too much in amp channels and processing, unfortunately. My tuppence worth, Andy |
torturing electrons since ......
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
You say "the stage is pointed the opposite direction of the town".
So the sound system is projecting into the audience, pointing away from the town. But a lot of bass energy will be going in the opposite direction. Recently I came across a sound system set up outdoors in a large park for a fitness class.Probably about 50 people. They were using a pair of stacks separated by about 4m, comprising single sub per side, with a JBL EON top box on a pole mount. They were playing "house" music at a decent volume. So I thought that I would have a listen. I walked about 100m back from where they were, and then I walked in a big circle all around them, keeping the same distance from them. In front of the stacks you got power alley as you expect. Tailed off at the sides. But as I walked around the back, there was almost as much bass as in front of the stacks, with a power alley in the same way as the front. I wonder you re-orientated the stage by 90 degrees you could take advantage of the tailing off at the sides? |
toastyghost
A horn loaded bass system at a reasonable mouth area & ground stacked is not comparable to a couple of reflex subs in terms of polar response.
The Punisher is a relatively small cabinet, but a stack of 6 per side would create a mouth area large enough to give a pretty directional response > 70 Hz. However the left/right power alley will be creating a laser beam of sound pressure both front and backwards. The best approach is to get off site and on site measurements done during the show by trained professionals who understand the type of event, have a hotline for complaints during the show to respond - probably the most effective tool based on a fair bit of research, even if the changes made in response to a call on site are minimal - and a bass array design that specifically targets off site noise reduction. Here’s where FLH subs are in an ‘unknown state’ as there’s a compromise between the required mouth area for the boxes to work properly, and the practicalities of array design such as spacing, offsets and the like. Reducing the mouth size will create significant ripple in the reactance of acoustic impedance, which translates to reduced linear output and possibly increased thermal rise and distortion. With the punisher being quite small and already at risk of overheating, you may need to consider a minimum of four boxes as one ‘sub’ for array purposes. A ‘graveyard’ of subs out front of stage is never going to fly, so going super deep in end fire isn’t really practical. You also have the issue of a relatively narrow notch in response at the rear. I’d suggest a two deep classic Olson gradient system in front of stage, and putting your mains on risers left & right instead if you can’t fly them. The maths is relatively simple, and you’ll get the most broadband cancellation. Yes, the timing out front is compromised further by an additional rotation in phase. However, you can consider whether that’s audible against the many other factors in play. It’s easy to add a second order all pass filter @ 63 Hz to a track of your choice in Reaper on your computer and listen with headphones versus an unprocessed track in an A-B test. If you can’t hear it then, you certainly won’t hear it out front on a PA. Yes, lots of engineers state they use end-fire for improved transient response, but I’d wager that in most cases the combined bass array’s response simply hasn’t been accounted for when aligning and tuning the system as a whole in the field. |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 623 |
Any pictures of the event available?
toastyghost
A latitude & longitude for Google Earth might be more useful mark up any noise sensitive properties. |
ceharden
You may find that the tent is in fact part of the problem. I've often noticed when doing gigs inside any kind of tent or marquee that you appear to get more bass outside it than inside (that may be mostly perceived).
If you imagine you've put a large source of bass inside a tent, it doesn't really matter which direction you point it because it's effectively going to cause all of the walls of the tent to move, re-radiating the bass, probably in all directions. Any kind of speaker directivity really only works in free space IMO. |
Requiem
Old Croc Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1805 |
Hi so I have a query linked to this same issue, around reducing noise pollution to the surrounding area for a 2 day festival.
The festival is a celebration of our sound systems 10th and 11th birthday so naturally we want it to be as impressive as possible, so the plan was to bring in a few extra subs so that I can set up 24x MA WSX & 8x EAW KF750, which of course are very loud cabs, I am trying to ease the disturbance to the local neighbours which are 400m, 650 and 750m away respectively, in opposite directions, across fields and low shrubs / hedges with some, but not much, tree coverage. I was planning a quadrophonic setup inside a barn with 4x stacks on PA risers (which is the reason I was going for 24, for 4x nice matching stacks of 6 +2), with noise propagation in the form of heavy acoustic draping around the inside of the barn, the walls of which are wooden slats. I was also planning to hang big heavy wool bales, which are fairly dense and absorbent, directly behind each of the stacks inside the barn , and then a 12m wide by 4.5m high wall of hay bales along one side of the barn which faces onto the closest, 400m away neighbour, who apparently is a right pain. I was hoping the quadrophonic setup would provide cancellation outside of the arena, whilst inside meaning that the audience members are never far from a stack, hopefully meaning we wont need to drive it as hard as we don't need to project it as far? and that the acoustic draping would contain the high frequencies whilst the wool bales and hay bale wall would reduce bass pollution. The farm owner is also keen to keep the sound within a respectable level. Our license conditions are harsh but not unusual, and we are expected to keep to 65db from the nearest residences . We will have our own person travelling between the residencies taking 15m average readings and staying in touch with us reporting back. I realise my plan probably seems ambitious, I would like to hear others view on it and if they have anything to add that could help? I've not tried a quadrophonic array before, I decided on it as we are having to reduce sound in three separate directions in a rough triangle, and due to the placement of the barn in relation to those directions. |
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 540 |
Bails of hay stacked up behind each stack should help.
toastyghost
I’ve been modelling ‘four point’ stacks - quadrophonic was a specific type of audio format - a few times in the last year using all sorts of cool toys. Unfortunately in almost all cases, it showed that the attempts at ‘controlled chaos’ are pretty much bogus, for the low end.
Get on Google Earth, make a project file and pin all the houses nearby that you can find. Those are your noise sensitive properties. Once you know where they are, you can use stage orientation, bale placement, and subwoofer array design to help get the results you want. It has a ruler tool so you can even do some basic inverse square law calculations. Assume the sub array is an omni or dipole source, set the broadband sub level you’d like in the low end on the dance floor (I find that 114 dBC slow with 130 dBC peaks is good) as the start point, and then just do some logarithmic maths to calculate the level at the given distance for the nearest house. Off your rough distances, a 65 dBZ level at the 400 m would be 117 dBZ on the dance floor. But don’t get too excited - an instantaneous peak isn’t a good description of nuisance noise. You need to consider the Leq - a time based average - with suitable weighting to compare on site levels to off site. The WSX is a FLH just like the Punisher, so my rule of thumb above applies. Treat a block of four subs as a single box, and design a gradient or end fire sub array to suit. If you need cancellation in a direction, put a two deep set of block of four subs facing the opposite way, spaced at a distance of 1/4 wavelength of your chosen centre frequency (63 Hz is a good start), then delay the rear stack the same distance and polarity invert it. Hey presto, broadband cancellation. You can put them central to the stage, off to one side, in three places all firing in - whatever. The cardioid array is what will do the work. If you wanna go ‘quad’ for the mains to give that vibe, then you can do that with them on risers. Just be aware that time alignment in those circumstances is a case of choosing points to average the error or ‘wrongness’ across… The AES paper on event noise management is open access, by the way: https://www.aes.org/technical/documents/AESTD1007_1_20_05.pdf Edited by toastyghost - 20 September 2021 at 11:09pm |
imageoven
Old Croc Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2186 |
400m to someone keen to complain? sounds like a non starter to me.
