  New Posts New Posts RSS Feed - Reflex Enclosure for 18Sound 21LW1400
PHATpedro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PHATpedro Quote  Post ReplyReply Direct Link To This Post Topic: Reflex Enclosure for 18Sound 21LW1400
    Posted: 10 May 2025 at 6:26am
Hi I am new here and I am searching the internet for a rexlex enclosure for the 18Sound 21LW1400 driver, as I am building my first rig.
I will buy two of those.
I want to build two single driver enclosures
This system will play mostly Dub, OG Dubstep, Jungle
I would like to tune this enclosure to 30hz or lower if that makes sense, but i think 18sound recommends 30hz.
Why so backwards?
I live in Mexico and I have very limited driver availablity, basically this is the only 21" driver i can get here where I am. I do not need to play brutally loud but I need to play deep. We have reggae soundsystems here that play incredibly loud, but that is not what i want.
Here is the driver
https://www.eighteen.it/en/products/lf-driver/21-0/8/21LW1400 - https://www.eighteensound.it/en/products/lf-driver/21-0/8/21LW1400
Resonance Frequency 28hz
Frequency Range 24-2000hz
Xmax 9,5mm
Recommended Volume 300L
Hopefully you can help me.
Kind regards
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 7:13am
If you are up to it, i can recommend this design.
It's not super easy to build, but it do sound good.
Heard them a couple of times, 2 subs each side with 2 EV RX212/75 on top each side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PHATpedro Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 7:45pm
I thank you for your response.
Unfortunately it is not what I am looking for.
I have discovered it on their webpage and it seems they used to have a single reflex 21" plan. I found several links iirc but theyre all dead. I would use it if it was still around.
I ofc. also like the ease of built for a reflex cab.
Thanks a lot.
