Reggae/dub soundsystem - bass cabinets |
moyojojo
New Member Joined: 25 May 2011 Status: Offline Points: 8 |
Posted: 05 January 2022 at 4:57pm |
Hello all,
Its been a while that Im out of this topic but I would like to build something and I need your advice. At the moment I have two 18ps76 and two LF18X401 speakers. Im thinking to buy one more 18ps76 and two LF18X401, I think its the best way to stay with the same type of speakers. I would like to build four bass cabinets and three kick bass cabinets, can you recommend something for me? I did quick research but I know your knowledge is better. What I found is for bass ESW1018 and for kick ES18BPH or Cubo18, are they really best choice? Idea of soundsystem you can find here: https://imageupload.io/i/IP021gbStZ I dont know if that RCF is suitable for some scoop, how do you think? I was reading that is quite simillar to famous PD1850 but I dont know which scoop plans to chose... Many tanks. Edited by moyojojo - 05 January 2022 at 5:05pm |
levyte357-
Suggest you sell all those drivers.
Then repost this in Scoop Forum. Take it from there. |
Esc4pe
Registered User Joined: 08 August 2021 Location: England Status: Offline Points: 165 |
You won’t want ESW1018 on the bottom if using kick section really, some people even use them as a kick section themselves! I’d recommend as above, work out the best cab you want (personally scoops for dub all the way) then get the driver that the cab was designed for.
levyte357-
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
LF18X401 does work fine in a reflex enclosure though. What kind of thing are you after precisely?
levyte357-
This thread has now moved to Scoops section.
moyojojo
Thank you all for replies.
To combine them with some kick bass cabinets. I was wondering about selling them but I want to achieve as much as possible with lowest bugdet because Im not using these speakers so often and I dont think it will change. So no chance for PD1850 or V18-1000... I can buy Fane XB18, they are even cheaper than my RCF but like I said, I think its better to have all the same speakers (?). https://forum.speakerplans.com/lf18x401-in-scoop_topic106749.html
Edited by moyojojo - 06 January 2022 at 6:02pm |
