  New Posts New Posts RSS Feed - Removing old logos from hex flight cases
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:19am
If life starts with the first one, it ends with a second one. By the second one, you really wont care half as much!
Just home schooling my two. I get STEM lessons funnily enough, although this mornings White Rose Maths is cooking. Go figure.
Any way, good luck!
Back to solvent of choice, you can buy cans of Graffiti remover, designed to lift (spray) paint off stuff. Start with one that claims to be "plastic safe" if it is plastic sheet clad ply flight case. Some of the more solvent based ones with dissolve the plastic as well, so start gently.
Obviously, wash your clothes and self after using solvents before going near new arrival. Wont harm the "baby" at all, but will send "mum" into an absolute hissy fit, which is far more dangerous to health.
Boxes-R-Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boxes-R-Blue Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 2:35am
Use a nail brush you NEVER intend putting near your nails and BA40 solvent, BUT do a little test first, Gun cleaner, Cellulose thinners, BA40 can all attack the finish of the diamond board and leave a f***ing nasty mess!
The "proper" way to stensil a case is an ink roller not, paint, that cleans off well, spray paint etc can be bitch. Jace's washer is a real option, but a steam stripper with a brass brush works.
I think BRP, Claire etc had it right with wooden road trunks!
