  New Posts New Posts RSS Feed - Replacing the pan belt on a iMove 5S/Acme Knight
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Topic: Replacing the pan belt on a iMove 5S/Acme Knight
    Posted: 23 February 2019 at 10:42pm
Hellos,
I need to replace a worn pan belt on a iMove 5S moving head. Do I remove the yokes via the base unit or go in from the top?
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2019 at 2:47am
Page 17 of the manual walks you through the steps to change the pan belt. You get a diagram as well, but here is the text.
Turn off the main power.
Unscrew all the screws (A) and open the base-housing cover (B).
Unplug all the connect wires (C) that from the arm to PC board and ignitor. Unscrew the screws (D) that fix the axis gear (E).
Change a new belt (F) by going through all connect wires that from the arm to base, and through the bridge for correct position.
Set up the gear axis to the bridge and screwed it. Note : do not press the belt.
Put the belt around the axis gear and motor gear.
Plug all the connect wires (C) that form the arm to PC board and ignitor.
Adjust the pan home position.
Screw the base-housing cover (B).
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2019 at 1:16pm
Thankyou James!
