Retro fitting driver bolt in system |
Post Reply | Page 123> |
Risc_Terilia
Young Croc Joined: 15 December 2007 Status: Offline Points: 699 |
Posted: 21 January 2018 at 7:04am |
I have some mt121 type 12" horns where the builder didn't install tnuts etc so the drivers are just screwed in. If I want to fit these without basically rebuilding the whole thing how can I do that without access to the front of the baffle? If there were such thing as threaded inserts with the outside thread reversed that would do the job.
Cheers Edited by Risc_Terilia - 21 January 2018 at 7:05am |
Timebomb
Risc_Terilia
Thanks but are you sure these has a reverse thread on the outside? It doesn't seem to say they do... Edit: Thinking more about this it doesn't actually need a reverse thread Edited by Risc_Terilia - 21 January 2018 at 10:21am |
Timebomb
No its a normal clockwise thread, but they work fine for mounting drivers when you only have access to the driver side.
Risc_Terilia
Cool thanks for your help - do you have experience with them? What size hold would you recommend for m6 inserts?
Timebomb
Thanks(1)
Yes i use them all the time, for a 12" mid driver i would use M6x13mm or longer if you have a 2x12mm baffle.
cravings
Thanks(1)
i have a 7.5mm drill bit which is a good size for an m6 tee nut or insert
Dub Specialist Sound
Thanks(1)
Wood inserts allk the way bro
fix your problem in ten minutes never use t-nuts on all my builds any more, pain in thea arse tha are |
Risc_Terilia
Yeah I got some thisarvo cheers. Any tips on using them with MDF (why people keep making cabs out of this stuff I don't know...!)?
Use them same way than any orther material,
done 1000s of them in MDF Builds no problems still...
mini-mad
..some people need heavy speakers! |
Yes we know the health risks ect alot ppl dont like MDF ect
Why is easy to work with, cheap , if looked after can still last a lifetime with a bit more looking after than plywood, and sound great still heavy box low and densed material whick build get bass boxs
