reverse Xover design |
TubeSpeaker
New Member Joined: 03 April 2023 Status: Offline Points: 2 |
Posted: 03 April 2023 at 6:57pm |
good day, i recently picked up a pair of custom built towers, using Vifa drivers, MTM and set up with tweeter inset for time alignment, solid built cabinets with 2 chambers tuned to various frequencies..
they sound "off" and after looking at the xover design, which uses good quality components but seems to be configured/ wired incorrectly. is there a reverse xover calculator where values can be entered in to a schematic and have it calculated with xover frequencies? thanks in afdvance!
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2545 |
Nope, it doesn't exist because there are a myriad of different ways to accomplish certain things so there is no "standard" template one could use to plug component values into.
But it's not that hard to reverse engineer a passive crossover, the most difficult part is determining what componets are in series with a driver and which ones are in parallel, doing that requires tracing the connections. Make a diagram of all this and add the component values and then you can figure out what the crossover is doing.. and then hopefully figure out what it's not doing right.
Earplug
There are some online circuit analysis software available out there, eg. CircuitLab, but I've never used anything like that, so not sure how useful it actually is. |
snowflake
if you tell us how many coils, capacitors, and resistors there are can probably deduce what sort of crossover it is. there are online calculators which you can give a crossover frequency and it then tells you component values for standard alignments.
