  New Posts New Posts RSS Feed - Rj45 in a xlr type body.
kevin tyler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Topic: Rj45 in a xlr type body.
    Posted: 03 December 2022 at 3:23pm
Hi guys
Hope all are well,
when you mount an existing lan cable in one of these plugs, do you have to snip the latch off the plug ?
Many thanks
Kev
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2022 at 4:34pm
No, there’s a cutout for it that you can see in the photos there.
The connection should still latch. The relevant EtherCon socket on the other end should release the latching tab on the RJ45 connector when the push tab on the socket is pressed.
If you’re making a new cable and termination to go in the EtherCon connector, then it’s good practice to tie the drain of the CAT cable to the outer ring of the EtherCon. That should ensure a shielded connection; commonly mixing desks such as the Behringer X32 won’t have a shielded connection to their digital stage boxes if this isn’t done.
Edited by toastyghost - 03 December 2022 at 4:37pm
BJtheDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BJtheDJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2022 at 6:10pm
Originally posted by kevin tyler kevin tyler wrote:
Hi guys
Hope all are well,
Many thanks
Kev
Same Page but in English
https://www.thomann.de/gb/neutrik_ne8mx_b.htm
If your vaccinations were mandatory and nobody in your class had measles,
then you know that you're not a Millenial kid.
</f
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin tyler Quote  Post ReplyReply Direct Link To This Post Posted: 04 December 2022 at 2:52pm
Thanks toasty ghost, it’s only the lan cable from my router to the berry x air,
Cheers.
