Robe Moving Heads - Not bright enough |
Page 12> |
yodominic
Joined: 18 December 2008 Location: London Status: Offline Points: 749 |
Topic: Robe Moving Heads - Not bright enoughPosted: 09 March 2009 at 10:55am |
Guys, I recently bought 2 Robe 575 xt washes and 2 * 575 xt spots. These were from an install so I have cleaned them and greased them and they look very decent with minimal noise. They came with correct used Philips lamps but the brightness is not what I expected from something that's 575 range. I have a pair of Acme Spot queens and these are only 150 and they are brighter than these. I don't want to spend any more money without isolating the issue
Has anyone got any ideas? |
Wrighty
Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
Posted: 09 March 2009 at 11:28am |
Lamp is probably tired. Unless the optics are filthy beyond belief... but you say you've cleaned them, so that shouldn't be a problem... Or is there a mechanical dimmer in them? I don't know a lot about these - just guessing based on what I've seen in some iMoves which I had to take apart a while back.
ALL YOUR BASS ARE BELONG TO US.
yodominic
Posted: 09 March 2009 at 11:31am |
I have cleaned them and the glass looks clear. Does the fixture gives out correct lamp usage hours? i.e can they be reset? |
imageoven
Joined: 28 March 2007 Location: Scotland Status: Offline Points: 2199 |
Posted: 09 March 2009 at 12:16pm |
Have you aligned the lamp? i.e. adjusted its position to give the best output. obviously it needs to be centered on the same axis as the lenses, but its position forward and back is important too.
Also check the optical path is clear, (I don't mean clean) if something isn't adjusted properly or a frost filter is selected without you realising (easy to do if your unfamiliar with the product) it will reduce output. other than that I would be thinking lamp life / quality, especcialy if you have two the same. lamp counters can usually be reset (for when you change the lamp). |
djdarren
Joined: 26 February 2008 Location: United Kingdom Status: Offline Points: 302 |
Posted: 09 March 2009 at 1:33pm |
I'd check the lamps, remember a 575 normal life span is 1000 hours which is not that much. After this time there brightness quickly goes down hill. Also every time you strike a lamp you lose an hour of life from it.
Wrighty
Posted: 09 March 2009 at 1:34pm |
If the light is decidedly yellow instead of nice metal halide bluey-white, that's another indication that the lamp is on its way out.
yodominic
Posted: 09 March 2009 at 1:39pm |
Thanks guys, i'll get a new lamp and compare the difference before buying for the rest of them as i have 2 spots and 2 washes. I have seen them on ebay for £88 inc postage i guess you can't get them any lower. The lamps are Philips MSR 575/2 |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 09 March 2009 at 2:07pm |
Thoman was always a fairly good source for cheap lamps, but that was few months a go now
yodominic
Posted: 09 March 2009 at 2:17pm |
Yes you're right they used to be , since the pound collapse it's all changed (£105 now) Edited by yodominic - 09 March 2009 at 2:18pm |
csg
Joined: 17 September 2007 Location: bedford Status: Offline Points: 6085 |
Posted: 09 March 2009 at 6:48pm |
Msr575 lamps are one of the worst discharge lamps out there - poor colour temperature consistancy is the main problem
the nominal lamp life is 750 hours, and will start to lose considerable intensity after approx 500 hours.
the most likely culprit is an aged lamp, with poor centering in the reflector. If the arc tube of the lamp is opaque white, light grey or pale yellow, then it is definately time for a new lamp
If the beam has a dark spot in the middle, or a bright spot to one side, then it is highly likely that the lamp is off centre which will reduce efficiency considerably
feel free to post a picure of the lamps, i service a lot of moving lights and am pretty good at judging the state of lamps
Preacher
Joined: 06 February 2007 Location: United Kingdom Status: Offline Points: 1174 |
Posted: 09 March 2009 at 7:53pm |
All those VL2C's keeping you working ![]() |
It's all about the music & the vibe, so enjoy it while you can.
csg
Posted: 09 March 2009 at 9:14pm |
yep, going to have a rummage around prg shortly, lots of vl2c's and vl4's for spares...
also working my way through about 40 macs at ther moment, most of which seem to have swallowed the contents of a df50's tank....
Page 12> |
