  New Posts New Posts RSS Feed - Rog’s Fabulous Carnival Extravaganza (Yawn)
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 8:53am
Originally posted by Preacher Preacher wrote:
saw one Void loaded lorry (a small lorry) have to say it was a bit off when it went past (but that could have been just at that point, or a DJ messing with the mix to much, like we had with spoony and his ragg it to red style).
One thing I did notice is that pretty much all the DJs were clearly using burned CDs of music they'd downloaded at home. So the quality of the MP3 going through the rig varied so wildly from tune to tune it wasn't worth riding the faders and EQ all weekend to try and put back the stuff that wasn't there in the first place.
Bryan M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan M Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 11:11am
God dam electricity on the meter! sat down and wrote a wicked review of the weekend only for the power gods to take it away from me.
Apart from this year being seriously hard work i had an awesome time. Putting simulated stacks into place and achieving the predicted results has given me alot of confidence in sound modeling software.
A big thank you to barney (sub bass) for all his help. will have another go this evening when i have a bit more time
bassmish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmish Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 11:53am
Originally posted by Rog Mogale Rog Mogale wrote:
Did see 28 amps on an Infinite 8 V2 at one point.
36 amps, Monday afternoon for a very, very brief period before we panicked about getting turned off completely
36 amps from 1 inf8????
that's nearly 8.3K and I thought it was rated lower at like 7K??? or can it still peak higher???
wow...
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 11:56am
how do you think I feel, every week it seems now I get a call out to one of my install for reports of distortion, when I arrive I find a DJ with the worst BURNED cd's
he then complains to me alsoAngry, then I tell the twat to put a BOUGHT cd, and lets listen to the outcomeEmbarrassedEmbarrassed
something has got to be done about this
back to a comfy sofa I goAngry
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 12:36pm
wow...
Not quite 8.3kw, remember no amp is 100% efficient. In fact, because they were all running at 2r a side they would have been 87% efficient.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassmish Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 1:48pm
yes but I was under the impression that this was a 7k amp meaning that it can draw 7k max, and if it's running at 90% efficiency then it would still be drawing 7k but only giving 6.3 to the speakers
anyway, 87% of 8.3 is still giving more than 7k to the speakers
so when people have been saying this is 7k amp they're not saying what it draws but its max output after internal losses or whatever, but infact it can do more than this?
I'll just looks at the specs..
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 2:30pm
Amps are rated by their output at different impedances as standard, not what they draw. Although sometimes the max current draw is presented in the spec sheet as well.
The Infinite 8 Mk2 is rated officially at 3700w per channel at 2r loads, but in bench testing it has put out more than that. Rog likes to give realistic and conservative power ratings it seems.
Drawing 36A, at 87% efficiency on a 230v supply, the amp would be putting out 7203w total which is just below the rated max output.
Edited by toastyghost - 04 September 2009 at 2:33pm
DCnoise View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCnoise Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2009 at 5:56pm
Thanks
NOISE BOYS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan M Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2009 at 7:54pm
Originally posted by mykey mykey wrote:
LOL some mighty fine paint skills there mykey. Rum and soca always sends me a bit mental
xlogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xlogic Quote  Post ReplyReply Direct Link To This Post Posted: 05 September 2009 at 10:29pm
Yes Notting hill was wicked! Shame i was working and didnt see the floats drive by. I saw the terrahorn float geting offloaded a the warehouse..looked heavy!
