Rounded off phillips |
Post Reply | Page 12> |
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
Posted: 17 June 2018 at 4:08pm |
Hi all , just thought I would give the heads up about how I tackle this as its just happened...really annoying when it odes...so I was removing a Phillips head screw (not countersunk) and it mashed up, had the correct bit too, my way of moving them is to use a pair of electrical snips and grab the top of the screw (same position as screwdriver) let the snips bite in to the metal and then clasp hard and turn...never fails.
Anyone else got a bot of kit that does it or other ideas?
Top banana
IainB
Registered User Joined: 25 November 2016 Location: Rushden Status: Offline Points: 422 |
Thanks(1)
Ive been known to either cut a slot across so that a flat head screwdriver works, or depending on accessibility use vice grips. Failing that... angle grinder or drill (depending on mood!) to take the head off, so I can remove whatever its holding on, then vice grips on the bit remaining.
Angle grinder is mostly used on the cars, wouldn't obviously use them on a delicate item
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
Thanks(1)
Rubber band between the screw head and the driver tip. It's a trick that has surprised many.
djeddie
^ This. I thought it was absolute b*&^%cks... until I tried it.
70,s hero
Good shout have to try that next time |
Top banana
mk2_ginger_biscuit69
i have a set similar to this. easy peasey long as there's access! Have a flexible drill shaft thing too so 99% of screws i have no problems with!
https://www.amazon.co.uk/SKmoon-Damaged-Extractor-Hardness-62-63hrc/dp/B01E9ZC2K2 Edited by mk2_ginger_biscuit69 - 17 June 2018 at 8:31pm |
Dub Specialist Sound
I use these to great results tbh
only few quid too angle grinder bit over the top
scott_fury
Registered User Joined: 28 October 2012 Location: Bristol Status: Offline Points: 319 |
Get a lot of this on the old motorcycles I work on. First I'd bang an old Torx/star bit into it, so that it goes in nice and tight and then use a T-handle or socket wrench to undo it. If that fails, get gash old chisel to cut a groove all the way along (or a dremel if you have one) and then get a flat head screwdriver at an angle into the top of the groove and whack it in an anti clockwise direction.
Edited by scott_fury - 17 June 2018 at 9:12pm |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2296 |
Impact driver, if it'll stand up to the hammering
GAZ.
Old Croc Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2433 |
Grab screw with side cutters if possible or failing that, Cobalt drill bit!
100% Earth Moving Bass
WILLZTHRILLZ
Registered User Joined: 21 April 2014 Location: up here Status: Offline Points: 201 |
Hammer n chisel 😁
70,s hero
Thanks for the replies, at least 6 ways to try
Top banana
