rse amps |
Post Reply | Page <12 |
cseko
New Member Joined: 24 March 2011 Status: Offline Points: 2 |
See pictures below... Usual PA design, and as you can see it got burned on a couple places. It look much worse on the back of the pcb, at some points the copper burned away, so I have no chance to reconstruct unless I have at least a diagram, or it would be much easier just to get a new PCB from the manufacturer but I can't really contact them, this is why I would need a phone number or something...
It's quite worth it even when I have to etch a new pcb, but I cant do it without schematic... What do you think? http://i537.photobucket.com/albums/ff339/cseko/IMG_1293.jpg http://i537.photobucket.com/albums/ff339/cseko/IMG_1292.jpg http://i537.photobucket.com/albums/ff339/cseko/IMG_1291.jpg http://i537.photobucket.com/albums/ff339/cseko/IMG_1290.jpg http://i537.photobucket.com/albums/ff339/cseko/IMG_1289.jpg |
bomdabass
Registered User Joined: 28 January 2011 Status: Offline Points: 10 |
Cseko your's is a much newer design to my SA800 as I suspected, yours has protection relays not that it's helped much!
Was worth looking I guess.
Try here if you havn't already www.cpsound.co.uk/products/rse_home.htm
kedwardsleisure
Can't you just copy the components off the opposite channel? They look like they're all in the same place.
North Staffordshire |
jimjam1977badger
New Member Joined: 23 April 2011 Status: Offline Points: 5 |
If you call Cp Sound on 01932842661 they will be able to help you out being the main distributer of the RSE amps.
sat121
New Member Joined: 18 August 2010 Location: LONDON Status: Offline Points: 1 |
Hi Ian
It Sat I lost your number Thanks
jbl_man
Sent you a message Sat.
