  New Posts New Posts RSS Feed - Rubic Horn
Rubic Horn
 Post Reply Post Reply Page  <1 14151617>
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2009 at 7:46am
Originally posted by colinmono colinmono wrote:
Take no notice, Rog and mykey are a bit like Statler and Waldorf, not very PC. We're not actually all a bunch of racists.
LOL perfect, apart from the racist bit
this thing keeps raising its head, is this a hint that it will be at carnival?
Joe_Kidd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe_Kidd Quote  Post ReplyReply Direct Link To This Post Posted: 08 October 2009 at 7:09pm
Originally posted by norty303 norty303 wrote:
You mean something like this?
http://www.speakerstore.nl/constructions/17
ahhhhh. They are beautiful Confused
jamwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2009 at 11:17am
Rog far from it for me to suggest anything to you
but would it not be easier to have the catches joining the units on the back and front internals so that you can lift each section into place then clamp together....
just a thought....
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 09 October 2009 at 11:46am
also as another idea that you will probably shoot down in flames.
there are catches using allen key to clamp in place basically a multi style hook that on a thread turns to catch and the when you further turn the key it winds in on a thread that locks tight will work in the 18mm ply and no flappy bits to rattle....
and another probably usless idea - what about rebating the ends and an external and internal 9mm x 9mm return and have a rubber strip on the internal edge of the internal rebate....
I shall f*@k of now shall I.......
bye
dj-panoramix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj-panoramix Quote  Post ReplyReply Direct Link To This Post Posted: 24 February 2010 at 12:17am
Originally posted by Contour Contour wrote:
This Rubic design is an impressive horn!
A few years ago we designed a similar concept (M-horn, see www.speakerstore.nl) but this was a folded frontloaded horn instead of rearloaded. For people who have little money but enough time this is an excellent solution to get much bass for little money. We also chose to cut the 18" horn in two modules for easy of transportation.
As far as I know only two people did build our M-horn (they were impressed with the loud deep bass) the main problem is no one was able to find the perfect solution on how to couple both parts of the horn. And how to prevent air leaks and rattles when the modules are on top of each other.
Best regards,
Walt
you talk about that ?
do you still have the parameter or a better plan ? just to look how it sim.
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2010 at 5:55pm
Yes he is talking about that.
Interested in sims too.
tweeter box View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tweeter box Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2010 at 6:39pm
Originally posted by Rog Rog wrote:
Rubic Modular Horn
Plots and pics of the seperate modules tomorrow.
whos the gay?
Electrikal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2011 at 8:39pm
  bump for been so damn sexy
fuzzylogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fuzzylogic Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2011 at 8:55pm
Dunno, the hat don't do it for me...but he's yours if you want him .
Edited by fuzzylogic - 03 November 2011 at 8:57pm
NEIGHBOURHOOD SOUNDSYSTEM
Infinitely baffled.
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2011 at 9:24pm
ClapPMSL Fuzzy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2011 at 11:37pm
Tocooltom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tocooltom Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2011 at 9:24am
Will we ever get to hear these cabs?
2 stacks of these on their sides making one big horn mouth would be immense....
Whats happened to these plans?...i want to see them!
Best regards,
Walt
Edited by Tocooltom - 04 November 2011 at 9:29am
This page was generated in 0.095 seconds.
