S18H Build México |
MrZuarth
Registered User Joined: 11 November 2005 Location: Mexico D.F. Status: Offline Points: 107 |
Posted: 27 January 2016 at 3:03pm |
Hello, I made the S18H with 18TBX100 horn, and I made a modification, the horn instead of going by in front, as the above will put the Yorkville LS1208, so it will put a Cruzeta to reinforce the speaker.
I have 4 acoustic boxes HD215 with Kapa Lite Eminence LF 3015, and 6 SPEAKER copies Turbosound TSE 111 with speakers Eminence Eminence driver Kapa10B and PSD2002 Possible cutting frequencies, subject to their opinions. S18H 40Hz-100Hz HD215 100Hz - 300Hz TSE111 300Hz - 17kHz - 4KHZ |
el chupacabra
Young Croc Joined: 02 August 2006 Location: United Kingdom Status: Offline Points: 757 |
HDs would be better run 80 to 250/280. Build looks decent, i hope you enjoy them.
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
A+...............Can you test the response and compare it B and Cs chart in their PDF??????? VECTORSONICS
Copa disco
Registered User Joined: 07 January 2014 Location: Brasil Status: Offline Points: 66 |
how well they sounds? From B&C chart it looks they are very loud cabs. how is the low end?
MrZuarth
For my taste they sound pretty good, I leave a picture of the complete system today, I will change the TSE111 treble means for the selenium model PAS3MA4
BP1Fanatic
Registered User Joined: 02 August 2009 Location: Columbus, Ohio Status: Offline Points: 105 |
Nice system!
