  New Posts New Posts RSS Feed - SAE PCM20  instead fp14000 Lab clones
sgarfa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sgarfa Quote  Post ReplyReply Direct Link To This Post Topic: SAE PCM20 instead fp14000 Lab clones
    Posted: 08 January 2018 at 2:47pm
fast question, to drive 3000w @ 4 ohm per side ..it's enough the PCM20....for now I use the sanway fp14000 (2017), no problem, but I'm always scared of not finishing the party
In eu where these sae can be found
DMorison View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2018 at 1:37pm
In the UK, Elements Audio.
Forum member Bee, who runs Elements, has posted that he's waiting on new product arriving IIRC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sgarfa Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2018 at 2:08pm
thanks very kind ...
Post Options Post Options   Thanks (1) Thanks(1)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2018 at 4:01pm
Yes, a 2x4800W at 4 ohm per channel. 2.66 omh stable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sgarfa Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 7:42am
why they are so sub-declared?
osse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote osse Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 12:17pm
Really? The company declares 2x3500kw at 4 ohms, are they that much more powerful?
Their declared specs of the pxm 1450 are very close to the measured tests of abeltronics, if it's the same (cannot see why not) with the pcm20 it's already very potent.
With about 3.8kw @ 2.6 ohm you could throw three 21" b&c drivers each side and probably give them a good beating as long as the psu doesn't crappy out and on a 32A feed
Have you tried the amp? I've got a pxm and have trust in their products
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 3:44pm
Osse, the figures are as true as specced, yes the new amps do boast some big figures, and pfc on some models. full details will be announced soon... (with in 2 weeks)
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 5:24pm
The new amp is not SAE made, but from the same engineer that opened his own production. So you wont find it on the SAE site.
PQM13 replacement too and few other amps are also coming.
SAE is more or less a dead horse now due to their completely unreasonable work policy and the quality seems to go down with every new generation of amps.
osse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote osse Quote  Post ReplyReply Direct Link To This Post Posted: 10 January 2018 at 7:39pm
Exciting to see the new products in 2 weeks :)
Edited by osse - 10 January 2018 at 7:45pm
unclejam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote unclejam Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2018 at 2:05am
Care to explain and or post some links?
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 11 January 2018 at 10:19pm
details will be available shortly...
but as Marjan has said, its the same design team, and sales, customer service team, infact alot of the sae staff lol... Sadly like alot of companys Sae have taken big short cuts in the current range, and are asking for order quantitys that are very unrealistic. Even if i placed my years worth of sale and marjans we still would be short on ther stupid minimum qty... pure crazy stuff going on... But the new range is a massive upgrade in quality and does offer even bigger amps in the light weight and transformer range..
Post Options Post Options   Thanks (0) Thanks(0)   Quote unclejam Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2018 at 9:28am
Awesome, any chance they'll have something that's a little friendlier on the compression driver side of life too? Having 800 rms on a 2 inch cd seems a bit silly.
