SAE PCM20 + Scoops + Roots Reggae : Any Feedback? |
Post Reply | Page 12> |
levyte357-
Posted: 14 November 2017 at 12:25pm |
As above from people doing this..
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Is that the lightweight or torroidal one?
levyte357-
Sure is SMPS PSU.
https://forum.speakerplans.com/amp-for-sub-use-4-ohm-sae-pcm-20-vs-pknc-xe6000_topic96459_page1.html
That's a good start.. |
vertx
Young Croc Joined: 14 March 2012 Location: Sydney Status: Offline Points: 578 |
I have two PCM20s powering eight PD186 in dual ported subs. Usually Playing techno, house/disco, DnB/Jungle and dubstep.
Never did direct comparisons but subjectively two PCM20s do better than: Two Soundstandard CA18s A Soundstandsard CA 18 and a SAE PCM13 A SAE PCM13 and a Outline T7 (or T9, can't remember)
This is all off Australia 240v 10a plugs. If I lend my PCM20s to any friends in Sydney with scoops I'll let you know how it goes. |
www.instagram.com/translate.sound
levyte357-
Thanks Vertx.
djkeet
Registered User Joined: 26 December 2011 Location: England Status: Offline Points: 462 |
Yes Levyte that fits my description on the face of it PCM2O is a very strong amp I replaced the CA18 first with PXM1450 then moved to PCM20 (Primarily due to getting the same amount of power, and me Nyjell having to move a rack with 12 & 18 in a confined space nah man etc) with less weight which has more head room than the 1450 in my opinion, but I could be hearing things so Im hoping to book a larger room early next year. So you might see me comment on fb and here and its not that I haven't done any real world testing I have but its not extensive enough so I don't make a big deal about it.[ Edited by djkeet - 09 December 2017 at 5:11pm |
Soundbite
MarjanM
Talk with Ben. There is a new amp coming.
djkeet
I mentioned that to Lev on FB MarjanM a few couple a weeks back new amp supposed to be stronger still Edited by djkeet - 09 December 2017 at 5:15pm |
Soundbite
levyte357-
Is new amp Transformer or SMPS?
djkeet
Cant remember whether Bee mentioned that, he did say the price range was near the same as some of the SAE's
Soundbite
MarjanM
SMPS, 2x4800W at 4 ohms.
djkeet
Or 2x3168 @ 4 ohms ,using Lev cal. Is it the same amp you were testing MarjanM? |
Soundbite
