SAE PXM 1450 Power Amplifier Feedback |
Page <1 171819 |
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 7450 |
Hi Marjan, that specs would indicate this would hugely outperform MA5000VZ, which has dual transformers, plenty of smoothing, and plenty of O/P devices. Could you please detail Transformer VA rating, Number of smoothing caps, voltage/ripple current, also number of output devices per channel, and make/models. I check these details before buying any sub amp.
Edited by levyte357- - 18 October 2018 at 1:30pm |
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7630 |
This is the only picture i have of that amp internals.
I am quite busy these days, but i will try not to forget to check all the datayou asked for. ![]() |
Here is the PXM1450 for comparison.
Good man.
Glad to see smoothing mentioned by Abletronics, has been addressed.
paulus ![]() Old Croc ![]() ![]() Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Offline Points: 3056 |
fair few years on now, just wondering how everyone is getting on with theres ?? also anyone done a a b test with the pcm 20 for example :)
Edited by paulus - 16 March 2022 at 10:04am |
TRENDSETTER SOUND SYSTEM
vertx ![]() Registered User ![]() ![]() Joined: 14 March 2012 Location: Sydney Status: Offline Points: 479 |
I've been running two PCM20s, a PCM13, and a PQM8 for a few years now. First few years had maybe 10 gigs a year. Now when COVID isn't shutting down dancefloors in Sydney we run it bout 2 times a week.
Had one PCM20 failure (during home use not a gig luckily) that was repaired by the local distributor (who has since stopped selling the amps fyi) But everything has been running fine since. But yes, my experience with the PCM series has been good overall, happy years on, and thanks to this forum for the word on em.
Edited by vertx - 22 June 2022 at 12:49pm |
that's great , just was interested as I have had it a fair few years now and it has really been amazing , i bought it brand new and have done many many events with it , running 2x 1850 a side and sometimes 3 , its very good on a 13 amp too due to its efficiently, i run it hard i use the lms to set brick wall limiter and run the amp up to clip and back it off the least i can to keep reds off , its fine run from 33 to 80 hz on drum and bass hire outs which are mainly 9 till 4am and my own sound playing roots and dub music , :) i have onned all the big crest and crown and the void but this for me is great i will add tho on the newer bigger boy drivers i think would need more power , we tested on the bnc sw115 18inch and it sounded very very nice but did run out of power this was on a 32 amp feed also , the crown 12000 did have more spl but that to was clipping just a side note
Edited by paulus - 22 June 2022 at 11:43am |
Interesting review. If it has a nice sound, and I can get them for same price as 5050, would try it with 1x 4 ohm big boy driver per side. |
Page <1 171819 |
