Samson MXS3000. |
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
Posted: 10 September 2017 at 7:23pm |
I have a query about the above. I bought one a while ago, but as usual haven't used it yet.
It has a filter switch, the options are:- 28hz (to prevent over excursion) Full (no filter) 120Hz which it says in the manual is a crossover. Now it's the latter which I'm not clear about. There are no other outputs, so presumably this is to separate bass to one side of the amp, and mid/top to the other........... but the manual doesn't say which channel is which. Any ideas anyone??? |
DMorison
Old Croc Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1647 |
Actually it is there, Page 11, para 2 of said manual says it is a High Pass on both outputs, eg for driving mains in a Sub-main system. You'd need another amp with both a lowpass and highpass filter to drive the subs - or an external crossover/DSP.
markie
But there are no outputs to send the signal to the second amp?
