Saturn 16 - 4 x 4200W - Discussion |
Post Reply | Page <1 34567> |
Author | |||
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
Did someone mention valve's? Terrible damping factor, old technology.... Stay away!!🤓
suiluj
Registered User Joined: 28 November 2007 Location: Phil/Singapore Status: Offline Points: 202 |
Are these two related? Seems below is his bigger brother. Edited by suiluj - 22 February 2019 at 2:26am |
BooM BASSTIK EleCtronics and Communications Engineer
Live in harmony with one another. Do not be proud, but be willing to associate with people of low position. Do not be conceited. |
levyte357-
Which amp is this?
Timebomb
Those pictures are of the old version of the power supply, the new one is more stable and more efficient, the supply's in the first Saturn 10s were the same as those in the picture, before the update.
bass*en*mass
real world experience tells me they are up for "the" job.. ;) (not sure if i would run them without backup options for high spec jobs though.. some doubts are left using one amp on sub, specially a rel. cheap chinese one.. glad they did work out well on this job though..) :)
levyte357-
I asked on 15th Jan, how many output devices per channel, no response yet.
ceharden
I recently repaired a 4kW (100% duty cycle) class D monoblock that will run into 1R loads. Guess how many output devices it had on each side of the half bridge? One! That question has no meaning without knowing the output devices and amplifier topology.
levyte357-
Topology already stated by seller.
Original question also requested power dissipation and manufacturer, but have lost interest now.
MarjanM
Why would the seller disclose all that info to you? Can you get an answer to those questions from Labruppen or Powersoft?
levyte357-
But this is not branded, is it? Not saying this is a Lab Copy/Clone, but ALL Chinese amp distributors I've spoken to, freely give hi res pics of output boards/PSU boards on request, if not on website. Many provide schematics with part no's on request. They know you are not going to copy amp, and will probably pass it onto your service engineer. Deton, Sanyway, Hypro Audio, XBS, will all do this. So nothing out of the ordinary requested here. |
spongebob
Young Croc Joined: 20 October 2010 Status: Offline Points: 1395 |
They probably give you all of that information because they think you'll place a big order
As apposed to asking alot of questions, making alot of statements and generally not buying anything |
levyte357-
Yes, you should buy an amp, based on what you are told, knowing nothing about components utilised inside it.. I remember Rog not only putting up internal hi res pics of Inf8MK2, but also pics of it on test bench, under going 50hz sine wave bench test, and measurements. How dare he be so helpful, without being asked..
Edited by levyte357- - 24 February 2019 at 6:39pm |
