Schematic / Manual Vestax PVC275 |
Post Reply | Page <123> |
Meat Substitute
Registered User Joined: 10 July 2020 Status: Online Points: 79 |
You should have that in your mailbox now...
T C
New Member Joined: 01 December 2022 Location: New Zealand Status: Offline Points: 2 |
Hi Meat
I recently purchased one of these mixers and two vestax turntables online. Turns out it's 100v gear not 240v which is what we have here in NZ. Looks like all three have been plugged in to 240 v . Fuses had all blown and the turn tables after a transformer mod I found seem cooked I'm guessing the same for the mixer but looking for a service manual to help. When typing in search your thread came up and I see you thanked someone for the service manual. Any chance you still have access and could share ? Thanks. |
Meat Substitute
Yeah, still got it. Can't send it via PM on here as you've less than 10 posts but if you put up your email I can send what I have.
T C
Hey
Awesome. Thankyou. Yes I've only just signed up. As it turned out , I've managed to get both turntables and amp running. Luckily just fuses had blown . Not sure what I posted earlier but have modified the tranny in turntables to take 240v from a YouTube clip but running vestax mixer through a an exterior additional tranny. Be keen to see a service manual . tom.star@windowslive.com Thanks again. Tom
Meat Substitute
You should have that now. Let me know if it needs resending.
RedLineGambit
New Member Joined: 01 September 2023 Status: Offline Points: 3 |
Hi, are those manuals still floating about
i got handed down this mixer and having a few issues with PGM 2, intermittently only comes out of the left side thanks in advanced
Meat Substitute
Yes, still got them. Can email them.
RedLineGambit
Hi Great,
would you be able to send them to wjbeats88@gmail.com
Meat Substitute
You should have that now. If there's any problem then let me know and I can send again. If
it's an intermittent connection then check over the phono connections
in the back. They weren't very well made and one slightly tight phono
can pull the sleeve off.
RedLineGambit
Thank you for sending the manual over and for the advice, i'll start with that :)
TigerKat
New Member Joined: 27 December 2023 Location: Sheffield UK Status: Offline Points: 3 |
Hi Meat Substitute, I was wondering if you could tell me where you got you schematic diagram for the Vestax PCV-275 please?
As I'm having problems with mine and I can't find them online. Thanks inadvance TigerKat
Meat Substitute
Can't remember where I found them. I've still got them though. Keeping old Vestax mixers running seems to be my main contribution on here at the moment. I travel to Sheffield 3/4 days a week normally so can do some sort of comedy spy dead drop of hardcopy manuals in a couple of weeks when I'm back at work. Alternatively, I can just email them.
