  New Posts New Posts RSS Feed - Schematics for Electro-Voice Zlx12-P
 Post Reply Post Reply Page  <1 181920
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2018 at 10:06am
it's because when you google for the diagrams this forum is no.1 in the results
North Staffordshire
nafo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nafo Quote  Post ReplyReply Direct Link To This Post Posted: 14 April 2018 at 8:46pm
Hey Voron , пожалуйста , пошли мне схему , zlx12 , my email is :  alikhar@rambler.ru
Thanks  Smile
Paul100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul100 Quote  Post ReplyReply Direct Link To This Post Posted: 15 April 2018 at 10:56am
SmileHi there,
Is there anyone who's brain I can steal??
I had a ZLX 12P in for repair. THanks to the help of the schematics I managed to fix it.
(Broken bridge and some minor components)
After I build it together again it works great but I get an error message "Thermal`on the display after some volume. It does matters if I use more bass in the sound. If I turn down the volume the message disappears.
I used new ordinary silicon isolation sheets after putting things together. The outside back black side of the  speaker does not get very warm.
In the pdf for the TDA 8953 (bass end stage amplifier) there is nothing written about a direct output indication of too high temperature only inside it regulates the output power.
I cannot find any measuring schematics what could indicate this error message.
Any help would be appriciated.
Thanks Paul
Smile
BTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BTN Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2018 at 4:30pm
Hello Paul,
Thank you for sending me some info about EV ZLX 12P. It does help a bit. I don’t know what to say how to appreciate you. Again, thank you very much.
HTY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HTY Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2018 at 12:58pm
Hello Voron,
Please send me good q SMD of EV zlx 12p,fo1u288988
Thanks you very much from Myanmar
kohanthuya@gmail.com
