scoop chamber sizes |
Page 12> |
| Author | ||
project 1
Topic: scoop chamber sizesPosted: 07 May 2011 at 8:40am |
what are the measurements for small chamber, medium chamber, large chamber, and what sort sound one can get from these different chambers sizes?
TechnoChef
Joined: 23 April 2009 Location: Oxfordshire Status: Offline Points: 1109 |
Posted: 07 May 2011 at 9:44am |
A large chamber gives deeper bass but less cone control. A small chamber gives higher power handling/SPL but less low frequency extension.
I don't know at what measurement it stops being small and becomes large though. Someone with more knowledge will enlighten us soon no doubt! When they do, could they also please explain what t/s parameters to look at in deciding whether a small or large chamber is needed? ta!
I think I'm in love with your mum.
Dub Specialist
Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3235 |
Posted: 01 June 2012 at 2:23am |
any answers/opinions??
RealitySound
Joined: 01 February 2011 Location: Bermuda Status: Offline Points: 1142 |
Posted: 01 June 2012 at 2:45am |
some info here; http://forum.speakerplans.com/pd1851-vs-pd1850-in-standard-scoops_topic63676_post634449.html?KW=scoop+chamber+size#634449
When you gonna send me some $$ mate ?
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 01 June 2012 at 9:22am |
As in all different types of boxes, perhaps only one speaker will be near perfect. whether small medium or large chamber, the compliance of the speaker will have a baring on cone control.
paulus
Joined: 14 December 2005 Location: SOUTH BIRMINGHA Status: Online Points: 3237 |
Posted: 01 June 2012 at 11:24am |
would say 9in down=small,9-11inchs=medium,11+ large
TRENDSETTER SOUND SYSTEM
paulus
Posted: 01 June 2012 at 11:25am |
just read that back it sounds obsene i am talking about scoop chamber sizes
Edited by paulus - 01 June 2012 at 11:25am |
project 1
Posted: 01 June 2012 at 11:34am |
Small chamber : 185mm - 205mm
Medium chamber : 205mm - 254 mm Large chamber : > 254mm Small chamber Most efficient, huge amount of pressure and throw, needs plenty eq to go really deep, unless 4+ cabs, Should have very good driver control, great for outside or large venues Medium chamber Good throw + SPL with efficient drivers, very little EQ to go deep, 2x cabs can go real low, OK driver control with good drivers, great for small/medium/large indoor venues Large Chamber Least efficient, Will go very deep with little or no eq, will be loud and deep close up, not as much throw, as above 2x, reduced driver control at high power, best for smaller venues All depends on driver used, if cab designed properly, length of rear baffle, expansion rate of cab. |
levyte357
Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
Posted: 01 June 2012 at 11:59am |
http://en.wikipedia.org/wiki/Plagiarism "Plagiarism is defined in dictionaries as the "wrongful appropriation," "close imitation," or "purloining and publication" of another author's "language, thoughts, ideas, or expressions," and the representation of them as one's own original work," |
JR.junior
Joined: 14 December 2009 Location: Slovenija Status: Offline Points: 1789 |
Posted: 01 June 2012 at 2:05pm |
Goal is to make chamber for geting 36Hz, don't need to go lower.
mykey-
Joined: 03 March 2010 Location: ID/UK Status: Offline Points: 6119 |
Posted: 01 June 2012 at 2:32pm |
the throw nonsense again
RealitySound
Posted: 29 July 2012 at 6:54pm |
Tony can you elaborate on this a bit for the 'less educated lot in all things scoop' |
Page 12> |
