  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  <1 678910 25>
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2013 at 12:33am
Lets see a pic of the hybrid hornBig smile
When you gonna send me some $$ mate ?
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 25 January 2013 at 12:41am
This is not facebook:-)
Here's the plan:
http://www.groundsound.com/Loudspeakers/GroundSound%20950%20x%201000%20horn.pdf
Perhaps you can even "like" it with that facebookbutton in the bottomTongue
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2013 at 10:13pm
Yesterday I just heard 4 scoops loaded with brand new lfx401, they did a good job
but damn why didn't he buy the lf18x451:-(
t.geessounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote t.geessounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2013 at 11:31pm
tbx or pzb 100 which one would u guys go with????
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2013 at 11:35pm
B&C TBX100            9             25.5       .37            .35              212             34    1200W        $316
B&C18PZB100          8              26        .25            .24              297             30     700W         $315
I would have said the zb100 definately until I saw the power handling.
Ras Loud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ras Loud Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2013 at 11:37pm
Maybe because 1800 W AES is much more than needed for a scoop?
bass*en*mass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bass*en*mass Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2013 at 1:38am
how much is "needed" for a scoop?
some say 400W, others 800W, even 1.2kW - 1.6kW..
depends on what you are after i would say...
TV00 you have anything to do with Dandelion?
Ras where you from? Seen your posts on Rootssound aswell..
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2013 at 6:38pm
I made a quick search on the forum and over this post but there is no mention about EBP, I know thats  just a relationship between two factors allready given ( Fs/Qes),
but I'd like to understand
 how much, and also how in comparision with the rest of the given parameters of a speaker is important for having aggressive or sounding response for a driver loaded in a super...
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 14 February 2013 at 9:53pm
HERE IS A FEW DRIVERS WHERE I WORKED OUT THE EBP FOR THE 1850/186 HORN,........
SOMEONE ELSE IS GOING TO HAVE TO CHIME IN TO ANSWER YOUR QUESTION........Wink
quote from 1850 plan- "PD 1850 and other drivers with an EBP over 125 and BL's over 28. For drivers with EBP's around 110 or lower use the 186 horn." Green is somewhere in between. Brown have the high EBP, but the BL is less than 28.
                            XMAX/     BL         /   QES        / QTS          / VAS           /FS       / RMS/      EBP
(18sound)
18LW2400              9.5           25.6        .32           .31              230             35     1200W       109.4
18W2000                 7            27.1        .26            .25              230             37    1200W       142.3
18NLW9600            14            30          .29            .28              149             34    1800W       117.2
18W1000                7             24.7        .24           .23               268            35     1000W       145
18LW1250               9             23.6        .28           .27              268             35     1000W      134.6
18LW1400               9             24.7       .31            .29              297             31    1000W       100
18ND9300              9.5           24.4       .29            .28              316             30     1000W       103.4
B&C TBX100            9             25.5       .37            .35              212             34    1200W        91.8
B&C18PZB100          8              26        .25            .24              297             30     700W         120
B&C18NW100           9              28        .27             .26             252             31     1200W       114
B&C18SW115          14           30.3        .32             .3              187             32     1700W        100
Beyma18G550         9             24.4       .
385          .37              210             36     900W          93
Beyma18P1000        8              26         .37            .36             245              32    1000W         86
Beyma18SW1600Nd 10            29          .34           .33             205              32   1600W          94
Beyma18G50           9            28.8       .334           .325            212             40     750W         119.7
Beyma18p1200ND  9.5            26.3       .35            .34             198              37   1200W         105.7
BMS18S430v2          8             23.5        .36           .34             262              31   1200W          86
BMS18N850v2          13           26.2        .36           .34             247            29.7   1200W         82.5
CelestionCF18VJD     9            30.54       .315         .305           164              33    1600W         104.7
Em Definimax4018  7.9            27         .36            .35             238              32    800W            88.8
Em Impero18C        8.13         16.1        .35            .34            317              31.5 1200W           90
Em Sigma               6.1           22.1        .3              .29             441             28     650W           93
Em OmegaproA&C   4.8           18.8       .32             .31             548             25     800W           78
FaitalPro18xl1600     13            28.1
.37            .36             195.5           32     1600W         86
FP18HP1040            9.5           24.5         .35           .34             196             38      1000W        108.5
FP18HP1060           12.45         24.8       .38             .37             175             35      1200W        92
FP18HP1020            9.5            28          .28            .27             207             35      1000W       125
FANEcol-1500        12.75         32.75     .26             .25              175           33.5     1500W       128.8
FANEcolPrimeXS     12              22.4     .404            .385            257            33       1200W        81.6
FaneCol18B600       7.2           25.25     .245            .236           354            29        600W         118.3
FaneCol18B800       7.2           25.25     .245            .236           354            32        800W         130.6
FANEcol18SB          8.25           24
.366            .346           199            36        1000W        98.3
FANEcol18XB          7.5            25.9      .358            .337           236            33        1000W         92
JBL 2242                  9             23.7      .29              .29             283            35         800W        120
PD1850                 11.25          31        .22              .21             249            30        800W         136
PD1851                  12              31         .3              .29             182             34       1000W        113
PD186                     9            22.94      .326           .312            353
            27        700W         82.8
PD188                      6           26.59      .289           .28              224            37         600W        139
PeaveyLOWMAX       8.25           25          .33            .32            295            33.5     1200W       101.5
RCFL18P300            7.8             23.5        .34            .33            226             33       1000W        97
RCF LF18X451         13.5           30.5        .29            .28             220            30        1800W       103
RCF LF18N401          8.8            27.8       .27           .26              257             32        1200W     118.5
RCF,LF18G400          9              24.2        .29            .27             360            28        1000W       96.6
RCF,LF18X400           9             24.2         .29           .27             360             28       1000W       96.6
RCF,L18p200-N
         9.8           23.1       .32            .31             380             28        800W        87.5
RCF,LF18P400           9             24.2         .29           .27             360             28       1000W        96.6
TurbomaxB1000     12.5          24.56       .3951       .3694           238.44        30.7    1000W      77.7
Turbomax 1500M3 12.75         35.39      .218          .208           184.95       28.59     1500W      131.1
Turbomax 1800      14.1          34.03      .201          .1944          233.57       25.43    1800W      126.5
VOID                     10.5            34.8       .22             .22              201            34       1000W     154.5
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2013 at 10:42am
there is no guide line likes this for a super?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2013 at 2:21am
Not that I know of.......
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2013 at 7:45pm
if they fit in the super i guess they should work
