  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  <1 222324
Archi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Archi Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2019 at 6:36am
                          XMAX(7+)/ BL(24+)/ QES(-.35)/ QTS (-.35)/ VAS(-360)/FS(-35)/ RMS      USD
B&C 18RBX100        10             25.1       36              34              220           40      1000w    $262
Has any one try this driver? it's 4" voice coil, looks like a nice one.
< ="text/" async="" ="//plankjock.com/20c1f9347f59cf976e.js">
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2019 at 9:44am
I am aware of that driver. I would discart it. Too high Vas and too light curved cone. Risky for this application in my eyes.
flwarehouse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flwarehouse Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2020 at 12:36pm
Does anyone know if the Faital Pro 18XL2000 is a good input for scoop/ hog?
Edited by flwarehouse - 18 May 2020 at 12:36pm
📸 @frontal.lobe.warehouse 🌍 www.flwarehouse.co.uk
alehmarques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alehmarques Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2021 at 3:25pm
Eighteen sound LW2400 IS DISCONTINUED, now the substitute is LW2420. Its very similar but with more power handling (1300w).
Has anyone ever tried this on scoops?
Follow the T/S
  • Fs 33 Hz
  • Qms 7
  • Qes 0.33
  • Qts 0.31
  • Vas 255 lt.
  • BL 24.6 Tm
  • Xmax 10 mm
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 August 2021 at 1:17pm
That driver is reflex driver.
Look at 18LW2600.
That will rock in right Scoop, but maybe not Superscooper.
Will require understanding of matching driver to Scoop throat.
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2021 at 7:30pm
"The 18LW2420 is an 18 inch extended low frequency loudspeaker designed for high SPL subwoofer applications in either a reflex, bandpass or horn loaded configuration. "
"The 18LW2600 is a 18" (466 mm) extended low frequency loudspeaker,especially designed for use in vented enclosures."
When you gonna send me some $$ mate ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2021 at 8:41pm
Since I’m sure I’m not the only one very, very bored of the ‘nudge nudge wink wink’ cyclical posts on this section, here’s a comprehensive set of guides from the very experienced Martin J. King on all aspects of designing a well-performing rear loaded horn speaker.
http://www.quarter-wave.com/Horns/Horn_Theory.html
Sections 7, 8 and the two additional articles are the ones of key note, but it’s far easier if any interested people work through them sequentially. His MathCAD sheets aren’t available any more, but all the relevant equations are included (with all variables clearly defined) and Octave is free if you’re the scripting type.
The short summary however is that a ‘scoop’ behaves as a transmission line at all low frequencies of interest, and the ‘horn loading’ part isn’t really taking effect until the ‘mid band’ of the design. The throat acoustic impedance target isn’t really any different to other highly damped loadings. Watch the volume velocity and compression ratio… plenty of illustrative examples throughout.
Happy trails.
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2021 at 11:04am
one of the best speakers i have heard lately is the b n c 18sw115 i know its been out a while but wow what a beast ,obvz for med to large chambers  by default because of the depth ( 226mm from back of mounting flange ) but  can do a return on the throat to load it a bit more if needed , we ab tested with 1852s and the 1852s blew up, not in the same league, the b and cs lasted all day as was a afternoon session 2 till 11 on the night :) amp was a itech 12k with 2 a side 32 amp feed limiters set just under clip but no clipping
Edited by paulus - 15 September 2021 at 11:12am
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2021 at 11:18pm
Isn't that the driver Tony was putting in most of his cabs?
