scoop compatible drivers... |
Post Reply | Page 123 25> |
RealitySound
Young Croc Joined: 01 February 2011 Location: Bermuda Status: Offline Points: 1140 |
Posted: 25 March 2012 at 11:15pm |
Found this by mistake. Don't know how accurate the list is but I'm sure others on here can add subtract to this list; It was made in '2004. Found it on dancehallreggae.com forum.- http://forum.dancehallreggae.com/archive/index.php/t-32236.html?s=8b398c52a449d83d54e2d67338b8cc81
Here is a list of 18 inch tranducers that will give you the best performance when using Scoops/Rear Loaded Horns & Earthquakes/Folded Horns Note: These are current models, and, you can contact me if you have a question regarding an older model. Cerwin Vega’s can be found used on Ebay Aura {Seismic} 1808 B&C 18 TBX 46 B&C 18 WB 46 Celestion Frontline 18 Cerwin Vega 188 EB Cerwin Vega 189 ES Cerwin Vega 189 JE {4 ohm} Cerwin Vega 189 SE Cerwin Vega 18S4 {4 ohm} Cerwin Vega 18S8 Eminence Magnum 18 HO Eminence Sigma Pro 18 Eminence Omega 18 Eighteen Sound 18 LW 800 Eighteen Sound 18 LW 1000 Eighteen Sound 18 LW 1250 Eighteen Sound 18 LW 1400 Electrovoice EVX 180 B Fane Colossus 18B 600 JBL 2242 McCauley 6256 North Creek Leviton P Audio C 18 600 LF P Audio C 18 650 EL P Audio E 18 300A P Audio E 18 600A P Audio IMF 18W P Audio R 18 100B P Audio R 18 76W P Audio SD 18 PAS LX 2800 Precision Devices PD 1850 Precision Devices PD 186 Precision Devices PD 184 Precision Devices PD 182 RCF L 18P 200 RCF Precision 18 G 400 Transparence 18 B 800 Void Acoustics V 18 1000 Its in alphabetical order. Be nice if we could arrange it into best-worst. Bless. |
When you gonna send me some $$ mate ?
TONY.A.S.S.
I don't know about the rest, but the B and C 's are old models. Even in the 2008 cat. it shows the updated version of the TBX46 which is the TBX100. In the Archive section of the latest cat, it shows the TBX46 out of production.
RealitySound
Cheers Tony,I realized that too. I have a TBX46, what is your opinion on it? Ok for scoops? Is the tbx100 alot better than it?
TONY.A.S.S.
If anything, it will have better glue technology and a better frame for heatsinking. Overall, it can't be too much different, sound will be similar but it does handle more power.
Edited by TONY.A.S.S. - 26 March 2012 at 9:09am |
hmaudio
Old Croc Joined: 03 April 2009 Location: Nottingham Status: Offline Points: 3844 |
does anyone no how well the tbx 46/100 will handle in an Ms-18? and if so what Mk would be best?
thanks Adam
This account is used by 2 people. |
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
EDITED
Edited by levyte357 - 11 May 2012 at 1:33am |
Dub Specialist
Old Croc Joined: 30 December 2011 Location: Smethwick Status: Offline Points: 3230 |
Fane
Edited by Dub Specialist - 12 September 2013 at 12:26am |
UpComingSound
Registered User Joined: 21 June 2006 Location: United States Status: Offline Points: 393 |
have any one ever put wood in front of the scoop woofer seal it in to make it a full folden horn? would it work ?
RealitySound
Alright, can we get back to putting this list together so that it can be of some help to people on here?
Maybe in order of best to worst with some prices. Some of us on here can't afford $1000 neos and would be happy to use a 'decent' inexpensive driver until we win the lotto. Or maybe it would be better to keep it in alphabetical order and give it a +number rating. +10 being the best etc. or +8 power handling, +6 performance in scoops etc. Aura {Seismic} 1808 B&C 18 TBX100- (Q331.50/ $340) http://www.usspeaker.com/B&C-18TBX100-1.htm Celestion Frontline 18- ($380) http://www.hollywooddj.com/cefr.html Cerwin Vega 188 EB Cerwin Vega 189 ES Cerwin Vega 189 JE {4 ohm} Cerwin Vega 189 SE Cerwin Vega 18S4 {4 ohm} Cerwin Vega 18S8 Eminence Magnum 18 HO- discontinued- http://www.eliminatorlightingdirect.com/EMINENCE_MAGNUM_18HO_18_HIGH_OUTPUT_DRIVER_p/290-586.htm Eminence Sigma Pro 18- ($170) http://www.usspeaker.com/eminence%2018-1.htm Eminence Omega 18 ($200) http://www.usspeaker.com/eminence%2018-1.htm Eighteen Sound 18 LW 800 Eighteen Sound 18 LW 1000 Eighteen Sound 18 LW 1250 Eighteen Sound 18 LW 1400 Electrovoice EVX 180 B Fane Colossus 18B 600 JBL 2242 McCauley 6256 North Creek Leviton P Audio C 18 600 LF P Audio C 18 650 EL P Audio E 18 300A P Audio E 18 600A P Audio IMF 18W P Audio R 18 100B P Audio R 18 76W P Audio SD 18 PAS LX 2800 Precision Devices PD 1850 Precision Devices PD 186 Precision Devices PD 184 Precision Devices PD 182 RCF L 18P 200 RCF Precision 18 G 400 Transparence 18 B 800 Void Acoustics V 18 1000 Feel free to comtribute to the list or add subtract from it etc. Bless. |
RealitySound
contribute rather..
RealitySound
Does anyone have an opinion on or have any experience with the Eminence Omega 18? in a scoop?;
Specifications: *Power handling: 800 watts RMS/1,600 watts max *VCdia: 4" *Le: 1.67 mH *Impedance: 8 ohms *Re: 5.2 ohms *Frequency range: 40-800 Hz *Magnet weight: 109 oz. *Fs: 25 Hz *SPL: 97 dB 1W/1m *Vas: 19.4 cu. ft. *Qms: 8.18 *Qes: 0.32 *Qts: 0.31 *Xmax: 4.8 mm *Dimensions: Overall Diameter: 18", Cutout Diameter: 16.56", Mounting Depth: 8.15". |
levyte357
EDITED
