  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  123 25>
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Topic: scoop compatible drivers...
    Posted: 25 March 2012 at 11:15pm
Found this by mistake. Don't know how accurate the list is but I'm sure others on here can add subtract to this list; It was made in '2004. Found it on dancehallreggae.com forum.- http://forum.dancehallreggae.com/archive/index.php/t-32236.html?s=8b398c52a449d83d54e2d67338b8cc81
Here is a list of 18 inch tranducers that will give you the best performance when using Scoops/Rear Loaded Horns & Earthquakes/Folded Horns
Note: These are current models, and, you can contact me if you have a question regarding an older model. Cerwin Vega’s can be found used on Ebay
Aura {Seismic} 1808
B&C 18 TBX 46
B&C 18 WB 46
Celestion Frontline 18
Cerwin Vega 188 EB
Cerwin Vega 189 ES
Cerwin Vega 189 JE {4 ohm}
Cerwin Vega 189 SE
Cerwin Vega 18S4 {4 ohm}
Cerwin Vega 18S8
Eminence Magnum 18 HO
Eminence Sigma Pro 18
Eminence Omega 18
Eighteen Sound 18 LW 800
Eighteen Sound 18 LW 1000
Eighteen Sound 18 LW 1250
Eighteen Sound 18 LW 1400
Electrovoice EVX 180 B
Fane Colossus 18B 600
JBL 2242
McCauley 6256
North Creek Leviton
P Audio C 18 600 LF
P Audio C 18 650 EL
P Audio E 18 300A
P Audio E 18 600A
P Audio IMF 18W
P Audio R 18 100B
P Audio R 18 76W
P Audio SD 18
PAS LX 2800
Precision Devices PD 1850
Precision Devices PD 186
Precision Devices PD 184
Precision Devices PD 182
RCF L 18P 200
RCF Precision 18 G 400
Transparence 18 B 800
Void Acoustics V 18 1000
Its in alphabetical order. Be nice if we could arrange it into best-worst.
Bless.
When you gonna send me some $$ mate ?
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 12:52am
I don't know about the rest, but the B and C 's are old models. Even in the 2008 cat. it shows the updated version of the TBX46 which is the TBX100. In the Archive section of the latest cat, it shows the TBX46 out of production.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 1:19am
Cheers Tony,I realized that too. I have a TBX46, what is your opinion on it? Ok for scoops? Is the tbx100 alot better than it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 9:07am
If anything, it will have better glue technology and a better frame for heatsinking. Overall, it can't be too much different, sound will be similar but it does handle more power.
Edited by TONY.A.S.S. - 26 March 2012 at 9:09am
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 11:07am
does anyone no how well the tbx 46/100 will handle in an Ms-18? and if so what Mk would be best?
thanks
Adam
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 11:33am
EDITED
Edited by levyte357 - 11 May 2012 at 1:33am
Dub Specialist View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 3:05pm
Fane
Edited by Dub Specialist - 12 September 2013 at 12:26am
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2012 at 3:33pm
have any one ever put wood in front of the scoop woofer seal it in to make it a full folden horn? would it work ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2012 at 2:36am
Alright, can we get back to putting this list together so that it can be of some help to people on here?
Maybe in order of best to worst with some prices. Some of us on here can't afford $1000 neos and would be happy to use a 'decent' inexpensive driver until we win the lotto. Or maybe it would be better to keep it in alphabetical order and give it a +number rating. +10 being the best etc. or +8 power handling, +6 performance in scoops etc.
Aura {Seismic} 1808
B&C 18 TBX100-  (Q331.50/ $340) http://www.usspeaker.com/B&C-18TBX100-1.htm
Celestion Frontline 18- ($380) http://www.hollywooddj.com/cefr.html
Cerwin Vega 188 EB
Cerwin Vega 189 ES
Cerwin Vega 189 SE
Cerwin Vega 18S8
Eminence Magnum 18 HO- discontinued- http://www.eliminatorlightingdirect.com/EMINENCE_MAGNUM_18HO_18_HIGH_OUTPUT_DRIVER_p/290-586.htm
Eminence Sigma Pro 18- ($170) http://www.usspeaker.com/eminence%2018-1.htm
Eminence Omega 18 ($200) http://www.usspeaker.com/eminence%2018-1.htm
JBL 2242
McCauley 6256
North Creek Leviton
P Audio C 18 600 LF
P Audio C 18 650 EL
P Audio E 18 300A
P Audio E 18 600A
P Audio IMF 18W
P Audio R 18 100B
P Audio R 18 76W
P Audio SD 18
PAS LX 2800
RCF L 18P 200
Feel free to comtribute to the list or add subtract from it etc.
Bless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2012 at 2:38am
contribute rather..
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 2:01am
Does anyone have an opinion on or have any experience with the Eminence Omega 18? in a scoop?;
Specifications: *Power handling: 800 watts RMS/1,600 watts max *VCdia: 4" *Le: 1.67 mH *Impedance: 8 ohms *Re: 5.2 ohms *Frequency range: 40-800 Hz *Magnet weight: 109 oz. *Fs: 25 Hz *SPL: 97 dB 1W/1m *Vas: 19.4 cu. ft. *Qms: 8.18 *Qes: 0.32 *Qts: 0.31 *Xmax: 4.8 mm *Dimensions: Overall Diameter: 18", Cutout Diameter: 16.56", Mounting Depth: 8.15".
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2012 at 2:45am
EDITED
