  New Posts New Posts RSS Feed - Scoop Identification and Advice
macca061 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macca061 Quote  Post ReplyReply Direct Link To This Post Topic: Scoop Identification and Advice
    Posted: 05 March 2025 at 4:34pm
Hi all,
Me and my mate are finally going to follow through on our longterm plan of getting a Sound together.
We have inherited two unidentified 18" scoop boxes and I wanted to reach out to the forum to see if we could get some help either identifying the build or get some input regarding recommended drivers to put into them.
The boxes came from the UK and look like they have been around the block a few times. We dont want to throw a pair of new drivers into them if they are likely to resonate apart and disintegrate on us!
Boxes are roughly 600x600x1200
Cant seem to include the images but here are the links:
https://imgur.com/nFoQQ0F
https://imgur.com/Cr8nxIl
https://imgur.com/fQPuwCA
https://imgur.com/JNVfyBF
Edited by macca061 - 05 March 2025 at 4:55pm
bob4 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2025 at 5:14pm
For some reason pictures from imgur can't be embedded using the forums picture inserting function.
Please have a look at the posting toolbar, in the top row there are tools for embedding weblinks, pictures, videos.
I made your picture links clickable.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2025 at 5:26pm
That pair of old warhorses looks rough as hell.
It appears as if the side panels consist of veneered mdf. You need to do some more digging to find out if they are any good. Without more detailed info, no one will be able to give you any credible advice. Which drivers are they currently loaded with?
Try to measure them up more precisely. Take the woofer out, make exact measurents of the backchamber, size of the throat etc. Ideally also try to measure the last part of the horn path, from inside the cabinet.
Edited by bob4 - 05 March 2025 at 5:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote macca061 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2025 at 5:30pm
Thanks for the reply, I will dig into them and see if I can get some more detailed measurements and specs!
Post Options Post Options   Thanks (0) Thanks(0)   Quote macca061 Quote  Post ReplyReply Direct Link To This Post Posted: 05 March 2025 at 6:39pm
I am reliably informed that the scoops are Larry Dub built.
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 06 March 2025 at 10:18pm
They are very similar to Larry Dubs true. All the Larry Dubs that I owned, had handles cut out at the bottom. They also seem very shallow. Larry Dub scoops were usually 750mm deep.
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 12:01pm
99.9% sure they not larrys , whip a driver out and post pic, will confirm then but as said they are to small depth wise and to wide width wise
TRENDSETTER SOUND SYSTEM
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 12:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote macca061 Quote  Post ReplyReply Direct Link To This Post Posted: 10 March 2025 at 6:47pm
Will do, they're housed in a mates shop at the moment but when I get into them next I'll whip out the driver and post a more informative pic!
