Scoop vs Tapped horn |
Page 12> |
sn95
Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
Topic: Scoop vs Tapped hornPosted: 12 January 2016 at 1:25am |
After reading a lot about tapped horn I got thinking about the two design and which one would have lower extension (play low) and have more spl and the pros and cons of each design. We know that size of the enclosure play's a big part of the equation I did so quick calculations of three of them . The Hog scoop ,The Super scoop and the T18 . The hog comes in at 21.038 cf or 595L The super scoop at 20.825cf or 589L The T18 is 14.832cf or 419L. Now to my understanding of the pro of scoops based on HR they appear to be a little more efficient than tapped horn and when a group of four they gain some extension on the low end .now the con due to there phase problem can't play over 90/100 hz. Now to the tapped horn pros play low in 1 box has directionality of the sound and generally are smaller .cons you get no additional extension from adding more. Please provide information if any of the information is wrong. Now the Question which of the designs will provide the lowest notes and highs spl all things being equal including the driver let's say the B&C 18sw115 the reason I use it is because its used in both designs. It would be nice if we have some actual measures of scoops to compare. I'm hoping to get some good feedback on the topic.
bass*en*mass
Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4007 |
Posted: 12 January 2016 at 2:43am |
would choose 4 othorns over 4 super scoops anyday when it comes to seriously low notes at high quality and spl. scoop might be slightly more efficient above 40hz but at the costs of smaller bandwidth due to shorter horn+backchamber.
directivity is slightly less on th due to smaller mouth/front area. there are some unscientific measurements floating around, search for scoop shootout etc., also some plots online of different scoop length/designs. imho, none of the "big sounds" i have heard had a significant output in the 30s. its all about the 45.. with a sturdy suitable driver and tuning they can shift some air though :) horses for courses - as always lol |
empiresoundsystem
Joined: 24 July 2015 Location: Derby Status: Offline Points: 100 |
Posted: 12 January 2016 at 12:09pm |
I have always wondered why OT horns aren't more prevalent in the soundsystem world.
A friend of mine keeps raving about them and doing sim after sim after sim. I've always believed to find things out for myself, so I may just build an OT horn and A/B test it against one of my superscoops. |
Failed DJ and fumbling through the world of pro audio. Give me a thumb and make me feel better:
www.facebook.com/empireAVWorks |
sn95
Posted: 12 January 2016 at 1:13pm |
The OT is another well designed and well documented is plan the only downside that I can remember off the top of my head its complexity of build and size but appears to be good to the high 20,s . I will do a little more reading when I get off work from that particular design
Sapro2
Joined: 31 January 2015 Location: Somerset Status: Offline Points: 352 |
Posted: 12 January 2016 at 1:30pm |
What is a OT horn? Never heard of them...
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
Meat
Joined: 05 June 2009 Location: Manc Status: Offline Points: 1513 |
Posted: 12 January 2016 at 1:34pm |
One of the likely reasons is the preferred driver which last time I checked was a very expensive B&C 21. I was very interested when the driver they recommended was the BMS 18N850v2 as I have a pair and liked the design. I've no idea why they changed their recommendations but I'd be still interested in a pair if they could be built for sensible money so long as this driver is actually ok.
Sapro2
Posted: 12 January 2016 at 1:38pm |
Is it a scoop? Tapped horn?
Splat Soundsystem
Meat
Posted: 12 January 2016 at 3:03pm |
It's a fairly large and long tapped horn.
http://www.data-bass.com/data?page=system&id=81 |
Sapro2
Posted: 12 January 2016 at 5:47pm |
Thanks
Splat Soundsystem
sn95
Posted: 12 January 2016 at 6:31pm |
You are correct about the B&C 21 being expensive but you could also use the SW 115
sn95
Posted: 15 January 2016 at 3:22pm |
After a lot more reading on the OT horn it appears that the trade off the design was willing to give up was some SPL and for some low in extension but knowing it has
manuelseth
Posted: 24 April 2020 at 4:58pm |
Hi everyone, Any of you have any suggestion about this tapped horn? it looks like a TH118 to me, but It's hard to belive Danley would share it.. quotes looks like the TH18.. Which driver according to you guys? https://ibb.co/54pnWXG - ![]() Cheers.
Edited by manuelseth - 24 April 2020 at 5:10pm |
Page 12> |
