scoop |
medi.root
New Member Joined: 31 January 2022 Location: ypres Status: Offline Points: 3 |
Posted: 31 January 2022 at 6:46pm |
searching for tha polar bear scoop plann thanks in advance
BigSoundNorthWest
Registered User Joined: 29 November 2014 Location: Manchester Status: Offline Points: 290 |
Fairly sure keV from Dub Smugglers saying he created them.
Good luck with that. You'd be better off asking him to build you some, or ask Joe at PCH to make u some Edited by BigSoundNorthWest - 06 February 2022 at 11:59am |
turbo7
Registered User Joined: 15 March 2009 Status: Offline Points: 233 |
i did once build one polar bear for comparison, it has a long horn but for drivers xmax greater than 10mm the throat is too small and it will suffer from turbulent airflow.
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
bob4
Wrong. Refer to the original polar bear thread linked by "jammin45" to find out who the creator really is
Edited by bob4 - 10 February 2022 at 4:47pm |
toastyghost
That’s not quite how a horn throat works, at least in theory. It’s not a vent, and the acoustic impedances of the rear chamber and first horn section either side of the throat opening will be much closer than a port meeting free air. The increased compression may push the air into nonlinear behaviour when driven at full chat, but thats more because the pressure at that point might exceed 150 dB as it can in many high power horns, even those for HF. Doing a proper analysis of the Polar Bear has been on my personal project to-do list for a while, but at first glance, a large portion of its clean, flat and powerful sound appears to be due to the fact it's been designed as a good transmission line as well as an efficient horn. Rear loaded horns aka scoops have an even smaller mouth than a FLH of the same dimensions, so the acoustic behaviour typically transitions from horn to quarter wave resonant pipe at the low corner. pfly is the designer and original builder, but I believe both Kev Smuggler and Matt at studio45 in Sheffield are licensed to build them. The plan isn't for general sharing otherwise, as far as I know. |
levyte357-
Pfly, that's him..
BigSoundNorthWest
My mistake guys,
Knew Kev Smugglrr had something to do with em
