Scoops with Eminence Kilomax 18s |
Post Reply | Page <123> |
Author | ||||
tkroeker
Registered User Joined: 06 November 2015 Location: kansas Status: Offline Points: 101 |
They might have other models as well. I really like the look of the Hogs and this project Im working will benefit from a neat look.
tkroeker
since I was looking forward to the $100 each and will probably go the Omega Pro route,,, If I did 3-18 hog scoops 2-HD15s 2-mt130s --on each side, outdoors as apposed to 4-18s each side How bad would my bottom end be?
nickyburnell
XMax of Omega very low. careful how you drive. Sigma has better xmax and is known to work in some scoops, but only 3" coil. Bottom line is Emmi don't really have the product for you.
sn95
Registered User Joined: 10 March 2013 Location: USA Status: Offline Points: 351 |
mini-mad
Really? Even though they brought out a scoop design book many years ago they don't have 1 driver that is useful?? ...strange.... |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
That book was originally Fane afaik, plenty of options back then.
nickyburnell
Yes, years ago, listen to 80,s Reggae, bass guitar etc not compressed 40hz mayhem. That designs suggested drivers were from a world gone by. Cue pedant quoting 80,s 40hz track, but you get my drift. EDIT: Cue not Que. Alcohol !!! Edited by nickyburnell - 07 October 2017 at 11:36pm |
mini-mad
Fair play... just thought they would keep at least designing knowing that the scoop was still a very active cab.
...yes fane wrote one too |
nickyburnell
Niche market, Emmi money in OEM
valve head777
Yeah, nearly took the bait lol..... |
njw
I can confirm that Omega 15's work VERY well in the HD15, very loud, very punchy, well defined bass and they go lower than you would expect in a group of four or more. Can't help in regards to using the 18's in scoops as I've never used an Omega 18 or a scoop!
nickyburnell
I don't know how to map cone excursion in Hornsrep for a scoop (should learn), I can do Bass Box Pro for reflex so understand the principles. I would presume the xmax would be a big issue with modern music in a scoop with an Omega and that Eminence really don't care about the niche market that is scoops?
However if the Gods are smiling the Kilomax has the travel, gotta be worth 100 dollars to have a play in a small chamber? Can always sell it and get 50% of your money back. Lev mentioned the Sigma years ago, keep it under control is the secret to all of these I would think? Make sawdust and break the rules! |
