  New Posts New Posts RSS Feed - sealed box or ported question
jruiz4659 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jruiz4659 Quote  Post ReplyReply Direct Link To This Post Topic: sealed box or ported question
    Posted: 10 November 2005 at 2:38pm
Hi
   I am making some front loaded 18" boxes I was wondering what would happen if didn't port them? can somebody tell me  the pro's and cons of sealed and ported boxes?
LunchieTey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LunchieTey Quote  Post ReplyReply Direct Link To This Post Posted: 10 November 2005 at 6:20pm
It depends on the driver. If it's prosound 18's then you'll have low output and likely overexcursion unless the box is small(even less output) It's(sealed) almost never considered for sound reinforcement
Speaker addict
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2005 at 4:34pm
Sealed boxes are generally more 'HI-FI' in that they usually have a flatter frequency output over the range they produce. The bottom of their range is usually higher, but they're bass roll off is generally more gradual from this point.
Ported boxes are usually much louder (as much as 10db in one system i looked at) and have a lower bottom end depending on where you tune the port, but once they reach this they roll off a lot sharper.
kev
