secondhand amps |
Post Reply | Page 123 4> |
Ianblumenfeld
Registered User Joined: 14 August 2020 Status: Offline Points: 50 |
Posted: 11 September 2020 at 1:31pm |
can I ask which are the best seconhand amps to go for please not the modern generation digital less than around £200 each thanks
Ianblumenfeld
oh, fogot, also specifically peavey amps go cheap which ones are the picks please, older school thanks, don't forget other brands, too
monkeypuzzle
Young Croc Joined: 25 January 2005 Status: Offline Points: 923 |
Matrix STR range and the 2u range, C Audio, Crown/Amcron, QSC, Crest...
All their old units are getting pretty long in the tooth these days but if you're patient, do your research into specific models and most of all, find a clean well looked after one it should do you fine. Worth changing PSU caps at the very least, maybe all the electrolytic caps. Really we need to know what you want it for,,,, Sub? Tops? DJ monitors? does it need to survive being dropped into the back of a van at the end of gigs five time a week or will it just sit there running your hifi? |
levyte357-
Crown/Amcron for £200 maybe not, unless you know of install clearing out.
Decent transformer sub amp, for 4 ohms, eg CA18, 5050 MA5000VZ, is still £600 upwards. |
levyte357-
Suggest you increase budget, or just not bother with PA.
Earplug
It depends on what you´re looking for, ie wattage. A 600W or 800W amp should be well inside the budget. A quick search finds Peavey CS or PV range, like CS800 or PV2 going cheap. |
Conanski
Best doesn't factor into the equation at that price just buy whatever you can find from a major brand name... meaning if you look it up on the web you have no trouble finding technical specs, user and service manuals, tons of reviews and web forum chat links.
Bams
Young Croc Joined: 08 April 2009 Status: Offline Points: 622 |
For that kind of money look at Kinxsound in the netherlands.. will get you a crest 4801, a bit more a 6001.. bargain basement is BGW amps.. 2x600w @4ohm. came out multiplexes so almost no scratches. 150 pound each..106 available..
levyte357-
Famous man once said, "you can't get into sound to make money, if you haven't got any".. |
M4trix
Registered User Joined: 23 June 2009 Location: Croatia Status: Offline Points: 445 |
mmm... yea it's possible. Build your own equipment ! Salvage electronic parts from TV sets, PCs etc in dumpsters, around repairing shops. Like I did...40 years ago !
4D
C-audio SR707 find one that's led a life of ease.
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
This is incredibly elitist and unhelpful. To OP - Look for c-mark mr, matrix str/ukp, behringer ep, alto, qsc rmx, peavey pv. cant think of any more off top of head but there are loads of contenders in that price bracket. Also if youve got facebook, get on rigresale and have a look/put up a wanted ad, loads of helpful folk on there (if not a bit too much banter for my taste :P). Hope that helps
