secondhand amps |
Post Reply | Page <1234> |
levyte357-
EP4000 is rebranded EP2500, nothing else. Not even worthy of being used as door stop.
kipman725
Registered User Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
It meets spec of 2400W bridged into 4 ohms, has decent SNR and is cheap due to brand perception.
jammin75
Old Croc Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2375 |
i had an ep 2500 years ago used on 4ohm bridge sub duty wasnt sayin anything
levyte357-
Thanks(1)
Brand perception is, it's cheap crap. Reason for this brand perception is, it's cheap crap. Anyone recommending Behringer EP4000 for sub, really do not know, what they are talking about.
jbl_man
Moderator Group Joined: 12 January 2005 Location: London. Status: Offline Points: 11154 |
Thanks(1)
Nice ones are becoming rare Midas,there are plenty of scruffy cs800's around cheap,but the nicer cs1000 and cs1200's are harder to find at sensible figures. Cs1200 has 32x MJ15024/25's in it, that's more than a Macrotech 2400 . |
midas
Old Croc Joined: 27 October 2011 Location: Cumbria Status: Offline Points: 2117 |
Agree the 1200 is scarce.. I was looking for one and the 808 came up first.
kipman725
What does speakerplans think of the Ecler Pam 1400? just pulled one out from under the bed assuming it was broken but has passed preliminary testing.
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Offline Points: 2572 |
I've owned loads of EP2500's over the years and looked after loads more EP's in various installs, not one of them ever put a foot wrong, even the ones running at 4r bridge on bass. Unfortunately I can't say the same for most of the 'brand' name amps I've owned/used. They sound just as good, are as well built and as reliable as the QSC RMX amps they're copied from IMO. You complain about people giving bad advice but to state that what are probably the best 'budget' amps are cheap crap and not worthy of being used as a door stop is just that. For driving low power bass bins (not subs!), mid tops or monitors you could do a lot worse than a Behringer EP.
Ianblumenfeld
Registered User Joined: 14 August 2020 Status: Offline Points: 50 |
i haven't noticed any really bad advice here i tend to avoid cheap chinese branded or chinese made if i can i also try to avoid berrys, i don't like what they do, copy others, inc. styling, like copycat supermarket brands and also they are made to a price, so they can't be as good i am just attracted to pv as you get a lot for your money with the covid, prices on the bay are still going high, sadly, much unrealistic pricing around there are no real bargains these days i tend to only go for top brands, you can't really go wrong but the experience and help ppl give here is invaluable, to avoid unreliable things i'm really greatful oh by the way, and old dog told me not to mix amps on mid and tops, etc. and there is a phase difference, even with different powers of the same amps
snowflake
Thanks(1)
bit of anti-Chinese prejudice
anti-Berry snobbery un-explained brand loyalty and faith that top brands always have value products perfect example! |
Ianblumenfeld
anti-Berry snobbery un-explained brand loyalty and faith that top brands always have value products nice one, looks like i'll fit in well here explanation ancient english proverb says you get what you pay for proper pro stuff...nice things cost money i am anti reverse engineering and copyinig using cheaaper components they could even use knock off transistors and have oscillation and reliability problems these pro companies have pedigree and legacy's going back to the 80s and 70s at least it can cost millions to r/d and get to market a product and the chinese try to short circuit the process and either make em abroad, and then get the design and reproduce it lawsuits have shown it its unethical, too cheaper parts worser spec and unreliable, too top brands are industry std for a reason, they work and do the job 24/7 I got introduced by my brother to good stuff started out with i think studiomaster mixer, c audios, ev's, then soundcraft now using lab gruppen, allen heath mixer, nexo's and kt dn360 and a pro engineer, you can't get a crest knock off on the cheap, surely??? and expect it to be the same they have the styling to a tee though, that and specs sell, along with price Edited by Ianblumenfeld - 18 September 2020 at 11:07am |
kipman725
you missed "oh by the way, and old dog told me not to mix amps on mid and tops, etc.
amps" you missed the appeal to ambiguous authority. In most cases this is a non issue as the amplifiers are linear time invariant systems and minimum phase with a flat frequency response in the band of interest. There are some exceptions to be aware of though: 1) Amps with DSP will have an intrinsic delay caused by the digital processing 2) Some amps (E.G inuke6000) are inverting and so will need the speakers connecting the other way round or the input signal inverting But if your using a measurement mic on the system (which you should be doing) you will quickly see these issues if they arise. For example I always wondered why I had to invert my subs when I was using an inuke6000 till I found out that it was inverting, it wasn't an issue as I had noticed the problem when adjusting the sub level and crossover and corrected it. |
