Setting limiters on Berry LMS |
Post Reply | Page 123 6> |
drivebycar
Registered User Joined: 28 April 2008 Location: United Kingdom Status: Offline Points: 440 |
Posted: 10 June 2009 at 1:45pm |
Hey,
I wanted to set up limits on our bins, and was wondering if anyone could give a bit of an explanation on how it works. I have a berry LMS. Had a play around with it but not entirely sure how to go about it Thanks |
AlfieDring
Young Croc Joined: 04 September 2006 Location: Bath, UK Status: Offline Points: 842 |
Ok no problem. Gather the following info.....
watts RMS powerhandling of bin(s) max watts RMS output of amplifier(s) Input sensitivity of amplifier(s) (in volts :P) And ill see if we can't conjour up some settings :) BTW i take it you mean the behringer DCX2496? Alf |
drivebycar
Hi mate,
Bins are loaded with pd186's so RMS is 700W Amp powering them is a Proline 2700 currently running one a side at 8ohm so 900W Dont know what the input sensitivity is though im afraid? And am at work so cant find out till later. Yep its a DCX2496 Cheers |
james folkes
Old Croc Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
i live in fear of dcx limiters... the only time i have ever blown speakers in my whole time doing this was when i decided to trust the ultradrive limiters to keep my amps out of clip. never again. norty has had some 18lx60s go pop under similar circumstrances too. i must temper this statement with information received that <20Hz run their hogs with the limititer lighting up all night long and have never had a problem.
i don't trust them though...
james.
mardy hippy.
AlfieDring
Thanks(1)
Hmmm ok, i cant find the 2700 input sensitivity either... bit annoying. All the other t.amps seem to be 0.775v so ill do a worked example with that and if the 2700 is different just do it again with 1 or 1.4 or whatever it is. Have a read of this thread from a while ago...... http://www.speakerplans.com/Forum/output-levels-input-sensitivity-dbu-dbfs-ummmm_topic23486.html?KW=%2B22dBu ... it will explain in a bit more detail the following maths. 0.775v = 0 dBu The ultradrive says +22dBu = 0dBfs so in order to output 0 dBu we set the limiter to -22dBfs. With the limiter set at -22dB the output from the ultradrive will be constrained to 0.775v and the output from the amp to 900w. To further drop this to 700w we work out the dB power ratio of 900/700 and subtract this from the previous -22dB... 10 Log (900/700) = 1.091dB -22 - 1.091 = -23.091dB Setting the limiter to -23.091dBfs should keep the output power down to 700w IF the proline has 0.775v input sensitivity. For different sensitivities see below. 0.775v = 0 dBu (as before ) 1v = 2.22dBu 1.4v = 5.14dBu So if for example its 1v not 0.775v just add 2.22dB to the previous answer giving -20.871dBfs. Hope that makes some sense. If not then check that thread i posted ^ chickenfizz shows another method for working this out that is i think equivilant? not totally sure though. LASTLY (at last!) I reckon you can probably safely put 900w into your bins anyway, would be very unlikely to cause a problem so you could just set the limiters to stop the amp clipping (-22dB) and not bother shaving off that last decibel EDIT: utterly forgot about release time. This parameter changes how long the limiter takes to open up again (under the control of an envelope, it dosent just ping open suddenly once the times up!) I reccomend for proper "limiter" behaviour setting it for the longest time possible or at least 5 seconds. Edited by AlfieDring - 10 June 2009 at 3:20pm |
drivebycar
Wow, thanks for that mate! Ill have a read of the other thread later on as well.
Timebomb
Yeah Proline 2700 is 0.775V unloaded which is -23.5dB on the dcx, the
clip point drops a bit when you put some speakers on it and drive them
them with a signal though, due to the voltage drop, we have had to put
the limiter down to -24dB on the dcx (as far as it will go) and take
the input attenuator on the amp down a little to stop it
clipping. Calcluated settings are never spot on, it depends on
how much vairation in voltage gain your getting through the amp, wich
vairies under different conditions.
Saul
Old Croc Joined: 15 June 2007 Status: Offline Points: 5912 |
i think there's also a way to set them for maximum gain structure.
you disconnect your cabs from the amps and then run pink noise through the system. Turn up the mixer until it just starts clipping and then reduce a little. Then run this into the LMS with the limiters off. and into your amp. turn up the amp until it just starts clipping, then reduce it a little. Remember the position of the amp attenuators and then turn them up full again. Then turn on the limiters and reduce until your amplifiers stop clipping. Once you've done all the bands, reduce the amps back to the "remembered" position, and reduce the mixer too. If your amps are too powerful for your drivers, this won't protect them, but it's easier than doing all the maths. I think i saw this in a DBX manual. I've personally always used the maths method, but i have tried the gain structure method, and it seems to work ok. Edited by Saul - 11 June 2009 at 12:40pm |
AlfieDring
@ Drivebycar, listen to this ^^^! Real world conditions always take priority over the calculations of an unknown stranger @ Timebomb, what your saying is good advice overall but where's this -23.5dBfs on DCX figure come from? Have you measured it to be different from whats indicated in the manual? The specs indicate -22dBfs for 0.775vrms not -23.5 |
jonminns
Old Croc Joined: 13 April 2008 Location: United Kingdom Status: Offline Points: 1877 |
I genuinely think ultradrive limiters are brilliant
Fairly unaudible, and they work I've overpowered v18s in tough boxes with the limiters taking 12dB off constantly all night to see what happens... nothing DBX DRPA limiters are sh*te however |
Tony Wilkes
+1 used correctly they can be very useful Tony |
james folkes
...which really makes me wonder, what on earth could we have been doing wrong that night? general opinion has it that they work, next time i have one out i shall have a furtle.
james.
mardy hippy.
