  New Posts New Posts RSS Feed - Setting limiters on Berry LMS
 Post Reply Post Reply Page  <1234 6>
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 4:36pm
Originally posted by AlfieDring AlfieDring wrote:
Originally posted by Timebomb Timebomb wrote:
Yeah Proline 2700 is 0.775V unloaded which is -23.5dB on the dcx, the clip point drops a bit when you put some speakers on it and drive them them with a signal though, due to the voltage drop, we have had to put the limiter down to -24dB on the dcx (as far as it will go) and take the input attenuator on the amp down a little to stop it clipping.  Calcluated settings are never spot on, it depends on how much vairation in voltage gain your getting through the amp, wich vairies under different conditions.
@ Drivebycar, listen to this ^^^! Real world conditions always take priority over the calculations of an unknown strangerLOL
@ Timebomb, what your saying is good advice overall but where's this -23.5dBfs on DCX figure come from? Have you measured it to be different from whats indicated in the manual? The specs indicate -22dBfs for 0.775vrms not -23.5
Edit, The -23.5dB limiter setting for the Proline came from sheet of limiter settngs i made up for different amps a while ago.  I was just taking it down another 1.5 dB to compensate for loading.
EG the behringer amps state +4dBU, so thats -18dB on the limiters, but thats loaded at 8 ohms (i think its 8 ohms, not sure).  Unloaded the behringers clip with the limiter at about -16.5dB.
The proline input states 0.775V, which is 0dBU, so the limiters can be set to -22dB, but thats unloaded, so i took another 1.5dB off for the seting sheet i made.
Yeah for 0.775V input you could start with the limiter at -22dB, but keep an eye on the amp and be prepaird to take it down a bit.
Also worth noteing that the behringers input sensitivity is 3dB lower when in bridge mode, im not sure on the QSC equivilent though, i know the qsc 4050HD is the same in bridge/stereo mode.
Edited by Timebomb - 11 June 2009 at 5:01pm
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 4:46pm
i normally need to run my dcx limiters at around -18 to stop clipping.
On my sub15 (PD154)
and wedges (BMS 12N620)
being run of 1 channel of a qsc rmx2450 each.
Is it because there underpowered?
Lignum_ww@icloud.com
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 4:49pm
If the RMX is the same as the behringer EP2500 wich mostly it is, then yeah -18dB is about right.
drivebycar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivebycar Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 4:50pm
So have the amps right open, and limiter set up as above, then bring the amp down if necessary?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 5:04pm
Yeah, or bring the limiter down a bit more if needed and leave the amps fully up.  Though the DCX limiter only gos to -24dB so you might have to take the amps down a little.
Post Options Post Options   Thanks (0) Thanks(0)   Quote drivebycar Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 5:07pm
Righto, definately worth a mess about as we might be hiring out soon. Thanks everyone Thumbs Up
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2009 at 9:09pm
Can you clarify this? are you saying it's 3dB less sensitive, ie requires +7dBU for full output, or the other way, +1dBU?
I might have to do a bit of Berri bridging soon.
Thanks
Kieran
Blahblahblah
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 1:09am
+1dBU as i remember, so -21 on the DCX, id check it first without the speakers connected though, should clip at about -19.5dB ish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 4:54pm
Thanks, very useful info, I'll give that a go.
I've sometimes used a less scientific approach and set the limiters as low as they go, -24dB, put a loud signal into the dcx, turned the amps up full, then raise the limiter until the amp just clips, then lower it a notch. A bit risky if you want to limit power to the driver, but works ok if you just want to avoid clipping. Not very easy when the amps are at the end of a 50m multicore though.
Blahblahblah
gwarntek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gwarntek Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 5:15pm
How come amps have switchable sensitivity then? Just incase you get a very weak input??
By choosing +1.44v over 1v or 0.775v, will it make the amp louder per dBu that is input?
Or if you use a higher sensitivity, you use a lower limiter threshold?
Edited by gwarntek - 12 June 2009 at 5:16pm
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 9:47pm
Exactly that, sometimes you have a weak signal, sometimes a strong one.  Changing input sensitivity just changes the working level or gain range of the input stage.
Nothing will make your amp "louder", for a given set of connected speakers there will be a max spl based on the speakers sensitivity, power handling and power supplied.  The max amp power doesn't change, the sensitivity figure just tells you how large an input signal will produce full output.
If you use a higher sensitivity (ie 0.775V) Then yes, you will need the limiter to start working at a lower level, as the amp will reach its limits with a smaller input signal.
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2009 at 10:10pm
i trust the dcx limiters implicitly on my rig, all the time, and haven't blown anything yet in 20 gigs. Set them only to keep the amps from showing me a red light ever. However I'm of the opinion that when trying to use em with an 0.775v amp, a 10dB attenuator between the dcx and the amp would be useful to get the limiter setting somewhere up nearer -14dbu than -24dbu. Lets the output D/A use more Bits!
20Hz can set his bass limiter at -24 and still make his Inf8's inbuilt limiters activate, so it's basically not doing much for him there. However the advice he recieved from Void was that his Inf8 + 4x V18-1200 combo requires NO extra limiting - the amp just sorts itself out via that nifty VPL circuit! Wish i knew exactly how that worked. Have to wait 50 years till the Freedom of Information Act kicks in eh :)
He's not blown anything yet though at a dance a few weeks back he managed, by the smell of it, to burn a layer of varnish off the coils. Had us all running up to him in panic "yer bins are cooking mate!!" but they lived to wobble many more days
