Setting limiters on Berry LMS |
Post Reply | Page <1 3456> |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8711 |
Ah gotcha that makes sense :) sorry for being a bit dim
mucsavage
Registered User Joined: 30 January 2007 Status: Offline Points: 226 |
This is a really great thread.
One question I am trying to confirm. Is the 0dB mark on the master output of a DJM-600 +4dbu? I am trying to confirm and searching for specs in Goggle but can't find it |
SamV
Usually is yes.
mucsavage
Ah just found this,
---------- Output Specs & Terminals Master Out 1 1 x (XLR) +2 dBu / 600 Ohm 1 x (RCA) +2 dBu / 10k Booth 1 x (RCA) 0dBv / 600 Ohm Record 1 x (RCA) -8dBu / 10k Send 2 x mono (Phone Jack 6.3mm) Headphone Monitor Out 1 x (Jack 6.3mm) -------------- http://www.gereg.co.za/CodeMaster/DJ/DJM600.html Would this be the values for 0dB on the master output? |
colinmono
Young Croc Joined: 10 October 2007 Location: Midlands UK Status: Offline Points: 1111 |
Yes, I think they will be the output for a 0dB meter reading. The specs in the manual give the master out (XLR) as 1.23V (i.e. +4dBu) though, not the +2dBu you quoted. http://www.pioneer.eu/uk/products/archive/DJM-600/media.html |
phildat
Young Croc Joined: 29 January 2009 Location: manchester Status: Offline Points: 1115 |
I use an aphex exciter in my set.if I tweak it is this altering the gain structure in a big way?
Its just a ride.
phildat
It's the 204 model...
Its just a ride.
hollywd901
Registered User Joined: 21 January 2011 Status: Offline Points: 22 |
still searching for my answer...here are my specs of my system, can someone please help with the limiter...thanks!
2 cabs loaded each with 1 eminence 3012lf speaker says 8ohms and 450 watts rms my amp is a behringer ep2500 says 500 watts rms @ 8 ohms (in stereo mode) input sensitivity of amp says: vRms (@8w) 1.23v (+4.0dbu) anyone's help is appreciated, the more i learn or think i learn, the dumber i feel... |
toastyghost
Thanks(1)
For sustained musical content with minimal crest factor you need to set your limiters a couple of dB lower than you calculate to relieve thermal stress on the drivers. If you're using an LMS that works in dBu rather than dBFS (seemingly all of them other than the Behringer) then use this: http://www.mediafire.com/?n7f4f4110tpf2mu It's been linked before but seems a fair few people have missed it. It helps you figure out the best attack time for the output's passband too, which is important because if you set your attack or release too fast you can end up with horrible bass distortion - an XTA unit does these calculations on the unit for you, if you want it to, and seems to do a pretty good job of it as well. I'm going to shamelessly copy this section from page 51 of the DP548 manual, which you can get from the XTA site here http://www.audiocore.co.uk/pdfs/DP548_manual.pdf. It's this kind of thing that separates the top tier of crossover units from good but cheap ones like the DCX in my opinion:
Unfortunately the DCX doesn't let you adjust limiter attack times, nor does it have automatic envelope adjustment as far as I'm aware. I currently use DBX LMS units, which do tick all those boxes but not on par with the quality of limiting you get from a correctly set XTA. Perhaps this is why people have damaged drivers despite thinking they have their limiters set correctly? Edited by toastyghost - 24 August 2011 at 4:41am |
hollywd901
can anyone help me with my limiter question 2 posts above,,,weekend is coming soon, thanks!
mucsavage
I think is it, open to corrections though: ------------ 0 dBu in Ultradrive = -22dB to get 1.23v out of the Ultradrive set limiter to -22dB + 4 = -18dBfs = 500W You want this to be 450W 10 Log (500/450) = 0.4575dB -18dBfs - 0.4575 = -19.54 dBfs ------------- |
Timebomb
Old Croc Joined: 11 October 2004 Location: Lancaster Status: Offline Points: 2717 |
Just start with all bands set at -24dB, 4000ms release, amp gains fully open, if a particular band runs out of headroom and hits the limiter then turn the limiter threshold up and watch the corresponding amp for clipping, if it clips then take the limiter back down until it stops clipping, calculations arnt going to be that accurate, voltage gain varies too much with most amps so your best just watching the clip indicator and adjusting limiter threshold.
